Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 860 overheating/update
[Return to Forum]
lonestarjeff
08-15-2012 08:18:19
75.35.171.22
Last summer I reported my 860 overheating in the
100 degree weather while shredding the pasture. At
the time I eventually chalked it up to chaff &
debris in the radiator, requiring me to come in
about every hour or so to clear the fins. Didn't
have any trouble after the hottest part of the
summer was over.
The same problem has come back the last couple of
trips mowing. I built a bumper since last year to
push more of the grass & weeds over before they
can get sucked into the grill, which has helped,
but my temp gauge continues to climb slowly thru
the green & after an hour or so into the red. At
that point I roll in & put some water thru the
radiator fins & it cools back down to the green.
I've played around some w/ the fuel/air mixture,
but my temp gun tells me the exhaust manifold temp
is around 600, so I don't think it's running too
lean. I thought maybe it's the gauge, but it held
steady all the rest of the year when ambient temp
was below 90. Checked the fan belt too.
I guess that leaves the water pump??
Jeff
[Reply]   [No Email]
Bret4207
09-02-2012 05:33:59
64.19.90.196
Re: 860 overheating/update in reply to lonestarjeff, 08-15-2012 08:18:19
When I rebuilt my 800 a few years back I put in a new radiator. The old one had been pretty abused and was close to 50 years old. After a time I found my temp creeping back up. I found that I needed to actually spend a lot of time blowing out the rad because the dust and seeds and dirt pack down in the fins. I also found, while replacing the water pump, that the fan blades had very little angle to them. Using a vice and my Mod 1 Eye Ball I added quite a bit of angle into the fan blades, enough that it looked "right" to me. Made a big difference of hot days.
Now I have to reroute the gas line since on a hot day working hard it will boil the gas in the line and "burp" at the sediment bowel. I don;t know why they thought running the fuel line next to the exhaust was a good idea.
  [Reply]  [No Email]
lonestarjeff
09-02-2012 10:53:35
75.35.171.22
Re: 860 overheating/update in reply to Bret4207, 09-02-2012 05:33:59
My radiator does pick up quite a bit of chaff too when mowing the high stuff, but I think Ford made these tractors w/ overcapacity in the cooling system, so they shouldn't overheat unless you're using most of that 45hp.
I have another temp gauge sitting in the shop for my 165. I think I'll hook it up & see what it shows after an hour.
Jeff
  [Reply]  [No Email]
pernell
08-17-2012 19:25:06
64.57.167.160
The original radiators had a divider plate in the top tank that would shake loose and lay down over sevral cores in the radiator. I'ts a lot of trouble but if your not sure, take the radiator off and shake it to see if it rattles, if so I guarantee that is your problem.
  [Reply]  [No Email]
lonestarjeff
08-18-2012 09:16:13
75.35.171.22
Re: 860 overheating/update in reply to pernell, 08-17-2012 19:25:06
I haven't specifically looked for the divider, but I have looked into the neck several times w/ a light. I've never noticed it in there, loose or otherwise. This is a '56 dated radiator, how was the plate set...lengthwise or short(front to back)?
Jeff
  [Reply]  [No Email]
Greg1959
08-16-2012 18:19:36
69.176.13.178
Preview
Posted: Fri Aug 17, 2012 1:17 am Post subject: Re: 860 overheating/update
I have been having the same problems with my 860. Rebuilt last winter. New hoses, thermostats (3), engine flush w/vinegar, another radiator, re-routed fuel line , new sediment bowl, new fuel shut-off at tank, new fan belt, tightened belt, new water pump, adjusted timing and carb. Still when it got into the high 90's, outside, It went into the overheating(red) on the gauge. I checked the radiator temperature with different candy and meat thermometers and the temps read 185(+)(-) 10.
Finally, I had a thought, I started the engine when it was cooled down(overnight) and watched the Temp gauge. I have a 165 degree F thermostat in now. At 900 rpms the temp slowly rose. The needle was just getting into the "red" when the thermostat opened for the first time and then dropped way back into the green.
At 165F I feel the gauge should not be in the "red" already before it opens. I bought a new gauge that I can actually read. I placed it in water with a candy thermometer and heated it up. It tested within a few degrees difference of the thermometer.
I'll get that changed in a few days and let you know the results.
New gauge....
This post was edited by Greg1959 at 18:31:43 08/16/12 4 times.
  [Reply]  [No Email]
lonestarjeff
08-16-2012 20:41:36
75.35.171.22
Re: 860 overheating/update in reply to Greg1959, 08-16-2012 18:19:36
Interesting....if I follow what you're saying, the
color-coded thermometer on your tractor(& maybe
mine)appears to be calibrated to a 160 degree t-
stat.
Man, I hope that's the case.
  [Reply]  [No Email]
Keith Williams
08-16-2012 06:25:45
24.142.137.38
All,
An even poorer man's test.
I put a "Frost plug heater" in my 4000. Got it in, put in new antifreeze and fired that mother up. As I stood beside the tractor admiring my great workmanship, the heater was pushed out of the block and I receive a quick shower of coolant. At least the tractor was not warmed up all the way!
But that makes you a lot poorer as that antifreeze went on the ground!
I found that I had not tightened the bolt enough that holds the heater in.
Enjoy.
Keith
  [Reply]  [No Email]
NoNewParts
08-16-2012 05:46:00
67.240.145.25
warm the tractor up and carefully remove the cap,
stick a meat thermometer in.
when the temp is at the thermostats number,
look in the neck.
flow should be very strong.
poor mans tests
take both hoses off the radiator,
put your garden hose in the neck turned up all the way.
bottom hose should easily drain and stay ahead of the garden hose
temporarily take out the thermostat, hook everything back up and fill with water. start the tractor and look in the neck, at different rpms
water circulation should be very violent.
If you look and think...'maybe that's good',
it isn't,
looking in at a good water pump running with no thermostat restriction,
leaves no doubt. they are strong pumps
very messy test but leaves no doubt if you can't see into the neck, take the top radiator hose off the radiator, stick a pipe in it, put your garden hose in the neck and start the tractor.
water should blast out that pipe
(beat me to it Chris :D )
This post was edited by NoNewParts at 05:47:03 08/16/12.
  [Reply]  [No Email]
RodInNS
08-15-2012 13:46:51
216.118.158.123
What say your heat gun when it's pointed at the thermostat housing? the block rail below the head? the oil pan? I think if you shot the block rail on the right side just below the head you'd get a pretty true jacket temperature...
Rod
  [Reply]  [No Email]
lonestarjeff
09-01-2012 14:37:18
75.35.171.22
Re: 860 overheating/update in reply to RodInNS, 08-15-2012 13:46:51
Had a chance to heat up the 860 mowing again this week. Didn't have time yet to try a flow test on the water pump, but I did shoot the block temps on it again.
When the dash temp gauge was on the line from green to red, my temp gun showed 220 between the #4 plug & temp sensor boss(on the head), 240 between #2 & #3(on the head), 160 at the t-stat housing, 160-180 along the block rail just below the head.
Jeff
  [Reply]  [No Email]
lonestarjeff
08-15-2012 17:51:45
75.35.171.22
If I remember correctly I was getting around 240 back toward #4 & 190 up front @ #1. That was shooting the head near the spark plug. All I remember below the head was the temp was considerably lower(140-160).
I didn't shoot the t-stat housing.
Jeff
  [Reply]  [No Email]
RodInNS
08-15-2012 19:29:53
216.118.158.123
Re: 860 overheating/update in reply to lonestarjeff, 08-15-2012 17:51:45
Try the thermostat housing and the area directly around the temperature gauge.
As far as the gauge goes... you can turn the indicator plate on the gauge needle shaft on many gauges so it's not exactly a science that goes with reading them...
I'd mabey expect the head around the plugs to be hotter which is why I'd really want to get a reading off the waterjacket on the upper part of the block.... somewhere you don't catch a lot of other radiant heat. It's a direct reading of the jacket that you want.
Rod
  [Reply]  [No Email]
lonestarjeff
08-15-2012 20:55:38
75.35.171.22
Re: 860 overheating/update in reply to RodInNS, 08-15-2012 19:29:53
I'll try it....it'll be another week before I'm up there again, though.
  [Reply]  [No Email]
hd6gtom
08-15-2012 12:59:54
75.170.237.148
I had the water pump impeller come loose from the shaft on my skid loader, did the same thing you talk about. New pump solved the problem.
  [Reply]  [No Email]
Dean
08-15-2012 09:01:55
67.172.15.77
I suspect it is the gage.
My 860 with 6 blade fan has done the same thing for years but never boils or pings.
I believe that non numbered gage is inaccurate.
Dean
  [Reply]  [No Email]
lonestarjeff
08-15-2012 17:58:37
75.35.171.22
Re: 860 overheating/update in reply to Dean, 08-15-2012 09:01:55
I'd like to think it's the gauge, but it slowly warmed up(5-10 min)& stayed steady right in the middle of green in cooler weather. The difference in 95+ weather is it just keeps slowly climbing. Haven't had the guts to see if it would peg.
Jeff
  [Reply]  [No Email]
soundguy
08-15-2012 08:44:21
173.103.87.138
might be time for a flow test into a bucket.
i have a 134ci that i may be putting a pump on.. I think the impellor is about worn off. a buddy has a 640 doing similar and we've been thru all the stuff you mention except pump as well.
gotta love summer heat.
my 134's on back burner as i'm mowing with a 950 right now.. :)
  [Reply]  [No Email]
lonestarjeff
08-15-2012 20:50:47
75.35.171.22
Re: 860 overheating/update in reply to soundguy, 08-15-2012 08:44:21
Hmmm...a flow test? That sounds like an interesting idea.
  [Reply]  [No Email]
Doug (OH)
08-15-2012 19:10:16
76.241.104.36
SG, would you mind explaining what a the flow test entails? TIA, Doug
  [Reply]  [No Email]
soundguy
08-16-2012 05:28:05
184.245.74.196
Re: 860 overheating/update in reply to Doug (OH), 08-15-2012 19:10:16
a 5g bucket and no thermostat, and a full rad with the cap off.
pump sucks from the bottom.. pushes out the top hose.
  [Reply]  [No Email]
Doug (OH)
08-17-2012 19:48:35
76.241.104.36
Re: 860 overheating/update in reply to soundguy, 08-16-2012 05:28:05
Thanks!
  [Reply]  [No Email]
soundguy
08-18-2012 08:17:57
173.105.0.246
Re: 860 overheating/update in reply to Doug (OH), 08-17-2012 19:48:35
post back if you hit any sags.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
