Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Low vacuum
[Return to Forum]
showcrop
08-13-2012 04:17:29
75.67.231.80
My 960 with carb from 961 makes low vacuum on the vacuum gauge and much lower than my 961. Any ideas?
[Reply]   [No Email]
David G
08-13-2012 16:21:05
205.215.206.18
 Re: Low vacuum in reply to showcrop, 08-13-2012 04:17:29
A lot of factors can affect this, what is the vacuum reading
on the 960, and does it run OK?
[Reply]  [No Email]
showcrop
08-13-2012 19:08:46
75.67.231.80
 Re: Low vacuum in reply to David G, 08-13-2012 16:21:05
I'll have to go back to the gauge to check the actual reading, but it is out of the green zone on the face of the gauge. The tractor runs very well, and has since I got the engine "blue printed" nine years ago. The only problem is that it doesn't pull the transfer sled as far as I would like it to, LOL.
[Reply]  [No Email]
awhtx
08-13-2012 15:47:59
74.84.89.147
 Re: Low vacuum in reply to GT65, 08-13-2012 04:17:29
[Reply]  [No Email]
MarkB_MI
08-13-2012 15:19:18
75.219.17.109
Let's back up: What inspired you to put a vacuum gauge on your tractors in the first place? Curiosity or an actual problem? If it was curiosity, and both tractors run fine, then why worry about it? If you were diagnosing a problem, then what is it?
[Reply]  [No Email]
JMOR
08-13-2012 12:04:40
72.181.173.171
 Re: Low vacuum in reply to Brian Allen, 08-13-2012 04:17:29
Exactly, John. I always like these two lines:
Everything that is known to be true isn’t. or,
A great many things that all know to be true, aren’t.
:wink:
[Reply]  [No Email]
John Smith8N
08-13-2012 11:43:00
76.253.185.2
 Re: Low vacuum in reply to jaluhn, 08-13-2012 04:17:29
You must not be old enough. From a cam manufacturer -
In the early 1950's the most popular original camshaft designers were the legendary Ed Winfield, the father of hotrodding, and Cliff Collins of Harman-Collins. If you look a Huntington's 1951 book you will find the specs for their cams listed. There were lots of cam grinders that copied Winfield and Harman-Collins cams, but these two were the designers and innovators in the early days. It was popular to refer to cams as a 1/2 Race or Semi grind and a Full Race grind. Later, there was a call for an intermediate grind between these two. To fill this demand, Ed Winfield took the intake lobe from his full race cam and the exhaust lobe from his semi cam and called it a 3/4 Race cam. It was literally half way between a full race and 1/2 race cam. Since that time, 3/4 Race has become a generic term for a high performance street cam, i.e. something less than a race cam.
From the current Crane Cams catalog -
Crane Cams #271-100172
Energizer 3/4 Race Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .450''/.450''
Duration: 274°/274°
RPM Range: 1800-5800
[Reply]  [No Email]
awhtx
08-13-2012 07:39:04
144.9.40.131
Does it have a 3/4 race cam? They don"t make much vacuum.
[Reply]  [No Email]
old
08-13-2012 10:36:41
209.86.226.32
 Re: Low vacuum in reply to awhtx, 08-13-2012 07:39:04
3/4 race cam that is a myth as for the term even being real.
[Reply]  [No Email]
Ultradog MN
08-13-2012 05:03:31
70.56.167.233
The simplest ideas would be a leaking manifold gasket or carb to manifold gasket. I don't remember if the distributer on those is vacuum advance but possibly a bad diaphram?
Next guess would be low compression.
Spray some starting fluid around the intake manifold and see if it is leaking. The engine will rev significantly if it is.
[Reply]  [No Email]
soundguy
08-13-2012 10:30:27
107.41.81.162
 Re: Low vacuum in reply to Ultradog MN, 08-13-2012 05:03:31
mechanical advance.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
