Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Ford 600 with no spark..... has spark
[Return to Forum]
dmiller
08-12-2012 19:55:17
205.162.160.227
New cap solved the last problem. Now have spark, still will not start, even with a shot of ether into the air inlet of the carb. Though, it did cough back once.
Guess tomorrow I do a compression test and check the cylinders. Changed the spark plugs out and the old ones were wet/gassy from all the cranking while searching for the spark issue.
So much for "ran when parked".....
[Reply]   [No Email]
soundguy
08-13-2012 08:03:56
184.246.23.68
 Re: Ford 600 with no spark..... has spark in reply to dmiller, 08-12-2012 19:55:17
pull plugs and clean em... do a thumb test on each cyl make sure you have valve action.
if she does indeed have spark, squirt a bit of gas in each cyl and put plugs in and roll over. yeah.. it washes the cyl down a bit..but this is a test..e tc.
you can always opt to re-oil the cyl and comp test her correctly.. etc.
[Reply]  [No Email]
Ultradog MN
08-13-2012 05:24:25
70.56.167.233
You might just have enough built up gas in the cylinders that it's fouling the plugs again.
Pull the plugs again and check for wetness. Or hook a chain on it and pull start it.
I would try pull starting it myself.
[Reply]  [No Email]
dmiller
08-13-2012 07:44:52
97.121.225.105
 Re: Ford 600 with no spark..... has spark in reply to Ultradog MN, 08-13-2012 05:24:25
I would too, except one of the rear rims is rotted from Calcium. New one ordered but not here yet.
[Reply]  [No Email]
old
08-13-2012 10:35:21
209.86.226.32
 Re: Ford 600 with no spark..... has spark in reply to dmiller, 08-13-2012 07:44:52
Pull the plugs out and spin it over with them out to clear the gas out of the cylinders. If I remember right this is still 6 volts right?? If it is do this and it will not hurt a thing. Drop a 12 volt battery into it and try to start it. That will give it a tad bit hotter spark and spin it over a lot fast so it can start a good bit easier. Then let it run say 10-15 minutes shut it down then stick the 6 volt battery back in and give it a try. Almost bet it fires up if you do the 12 volt battery thing
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
