Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 841 power steering water
[Return to Forum]
pete hall
08-09-2012 03:12:55
75.235.60.246
I have a 841 with factory power steering that gets water into the system over a period of time.The resevoir cap is good.any ideas on how moisture can get into the system?
[Reply]   [No Email]
john_bud
08-09-2012 13:01:50
173.245.138.22
 Re: 841 power steering water in reply to pete hall, 08-09-2012 03:12:55
I would first flush the system out 100%. It"s messy, but needed. You have to cap the return port on the reservoir and put the hose into a clear container. I use a sports drink bottle as we have lots of those around. Clean the filter & reservoir with gas or carb cleaner then fill with fresh hydraulic fluid. I use hydr fluid over PS fluid. Crank the engine but don"t start it. Watch the level. When it gets low, stop cranking and refill.
After a bit, it will run clear. Then turn the wheel full lock to the left. Repeat the cranking / filling until clear. Then turn the wheel full lock to the right and repeat.
At that point, you can then refill, cap the reservoir and actually start the engine. Let it get up to temp and then run the wheel full lock left and right a half dozen times. Check the reservoir for contaminated fluid. If you"re lucky, it will be clear still. If you"re typical, it"s back to the crank&fill until it"s actually clear.
Water can come in from many places. The top of the steering column seal could be weak, the reservoir gasket could be not sealing or it could just be getting condensation in the fluid because you don"t run it hard enough for long enough.
[Reply]  [No Email]
soundguy
08-09-2012 04:58:37
173.104.129.30
a little water goes a long way when emulsifying oil. if it was water logged real bad and you only drained the top sump .. then the oil inthe lines and cyls contaminated the new oil. might take 2-3 full changes and treatmet to actually get all the water out.
cover got a good gasket?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
