Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Jubilee hydraulic check valve
[Return to Forum]
steckmeyer
08-07-2012 11:57:10
71.61.10.82
The 3 point would not stay up when the tractor was off so we got into the hydraulics. We cleaned the valve spools and replaced the pressure relief valve in the bottom of the case. When we took the check valve apart we did not find a steel ball or a glass ball (I heard sometimes it is glass) but a plastic ball. I don"t know if the previous owner did a quick fix or if Ford thought this is a good idea but the plastic ball is all scored and rough. We tried to clean it up. Back together it the 3 point will stay up if nothing is on it but the lightest load caused it to drift down.
My questions:
1. Anyone know where I can get a replacement steel ball?
2. Anyone know the correct diameter for this ball?
As always thanks for your formidable help.
[Reply]   [No Email]
Sean in PA
08-08-2012 06:20:13
71.224.102.32
 Re: Jubilee hydraulic check valve in reply to Mad Farmer, 08-07-2012 11:57:10
The only steel ball that I can find for an NAA that's labelled as #26 in the New Holland parts site is on a different drawing, for the top cover, not for the lift cylinder. It doesn't list a part number, just PL "Procure Locally" and the description says "Ball, Steel, Except NAA, Start Year 1/1/1955", which to me means that it doesn't exsist on an NAA (Jubilee) at all, and only on the later hundred series.
[Reply]  [No Email]
steckmeyer
08-08-2012 02:43:16
71.61.10.82
 Re: Jubilee hydraulic check valve in reply to steckmeyer, 08-07-2012 11:57:10
Based on the diagrams I"ve found NAA part # 354069-S (page 5-12 Master Parts Catalog) or NH diagram #18 is the feed check valve for the lift cylinder. Am I wrong? What is the function for part # 353075-S (page 5-2 Master Parts Catalog) or NH diagram #26? Thanks
[Reply]  [No Email]
Michaels Dad
08-07-2012 16:44:28
209.173.113.5
 Re: Jubilee hydraulic check valve in reply to Brian Allen, 08-07-2012 11:57:10
While we're on the subject, I'm having the same problem with bleeding down, and locating the ball for my 640 shown in the repair manual on the CNH parts pages.
I've looked at cover and hydraulic lift parts and still can't find it.
Bad thing is I just got new trifocals.
Finally found it, #26, procure locally, 15/32" steel ball.
Now, where to buy only one, not 100.
The blind hog finally found the acorn!
This post was edited by Michaels Dad at 16:57:14 08/07/12 3 times.
[Reply]  [No Email]
steckmeyer
08-07-2012 15:56:25
71.61.10.82
Sean, Thanks again!
Soundguy it is #18. I think this is the problem.
We will see tomorrow when I visit my NH dealer and buy one.
Have great evenings.
[Reply]  [No Email]
soundguy
08-07-2012 17:29:39
173.103.84.98
 Re: Jubilee hydraulic check valve in reply to steckmeyer, 08-07-2012 15:56:25
interesting. 18 shows as a stud on my parts list??
wait.. are you guys talking about the ball under the safety valve on the cyl then? and not the ball accessable from the front of the front cover then.
ahh.. 18.. that makes sense.. :) wrong diagram
[Reply]  [No Email]
JMOR
08-07-2012 15:04:52
99.105.24.57
Quoting Removed, click Modern View to see "Jubilee hydraulic check valve
Darn message title get me all the time too. :wink:
[Reply]  [No Email]
Sean in PA
08-07-2012 14:52:06
71.224.102.32
I can't give you a direct link because the parts lookup page uses session information in the URL, so if I give you my link, you'll get a message that your session is no longer valid. You can start at the main new Holland Agriculture products North American web page CLICK HERE. Then point your muse at, but don't click on, "Parts & Service near the top of the page, and then click on "SEARCH FOR PARTS" from the menu that pops up. Once you're at the parts lookup page, type in NAA as your model number and click the search button. Then click on "NAA 4 CYL AG TRACTOR ALL PURPOSE (1/53-12/54)", which should be at the bottom of the list. Then click on "Hydraulic Systems" and then click on "05B01 HYDRAULIC LIFT CYLINDER, SHAFT & RELATED PARTS, 53/54".
This post was edited by Sean in PA at 14:53:36 08/07/12 2 times.
[Reply]  [No Email]
steckmeyer
08-07-2012 13:33:56
71.61.10.82
Sean,
Pleas give me that link. I"ve been using the Ford Masters Parts Catalog but sure would like to find the New Holland one. Thanks
[Reply]  [No Email]
Sean in PA
08-07-2012 13:02:01
71.224.102.32
If it's the part labelled 18 in the parts diagram for the lift cylinder on the New Holland parts web site, then it's a 7/16" steel ball, part number 86520978. You should be able to get it at your New Holland dealer, or on line at messicks.com.
[Reply]  [No Email]
soundguy
08-07-2012 15:02:25
173.103.3.96
 Re: Jubilee hydraulic check valve in reply to Sean in PA, 08-07-2012 13:02:01
if it's the one on the outside of the front of the lift cover it should be #26
which one is he looking for?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
