Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 641 Clutch Throw-Out Bearing
[Return to Forum]
mooboy
08-07-2012 03:56:43
67.72.98.45
For the past two years the throw-out bearing squeaks whenever the clutch pedal is depressed. The clutch is otherwise strong. This tractor gets used about 40-50 hours a year mowing, tedding, raking hay. Any downside to use as-is till clutch fails? I have never split a tractor before. How hard is it?
[Reply]   [No Email]
36 coupe
08-08-2012 03:26:44
66.186.169.176
 Re: 641 Clutch Throw-Out Bearing in reply to mooboy, 08-07-2012 03:56:43
A bad bearing can ruin the pressure plate.
[Reply]  [No Email]
john_Bud
08-07-2012 20:55:08
173.245.138.22
It's not hard, but you will thank yourself if you do it on a hard surface like cement. You need to have a fair selection of jacks, stands and maybe even a engine hoist. I happen to have those things and they make getting the alignment just right a lot easier.
On a 640 loader tractor a buddy owns, I did the split, and new clutch with new trans input shaft seal and surfacing the flywheel in about 8-10 hours. The inside of the bell housing was gooey and cleaning that up took time. That was working alone. With help you can either knock off a couple hours or quadruple the time, depending on the helpers!
There is no real down side to just running it till death occurs. Except when I do that, it usually dies while crossing a mug bog with a heavy attachment on the back in a field where I can't get a truck out to it! Oh and it's usually before a rain that turns to sleet! That's why I prefer to plan the repairs for when I have the time and can pressure wash everything first and have it all clean and dry. Makes life much easier that way.
[Reply]  [No Email]
reb-in-pa
08-07-2012 08:05:31
134.198.95.143
If your "squeak" is really a high pitched "squeal," then I agree that the throwout bearing is the likely culprit and that it can't wait too much longer. Squeak = relax; squeal = get out your manual and hoists.
Good luck.
reb
[Reply]  [No Email]
reb-in-pa
08-07-2012 04:43:50
134.198.95.143
mooboy --
How do you know it's the throwout bearing that's squeaking? I think that, if that bearing were getting dry, it wouldn't be squeaking. It would be more of a scraping or grinding sound. However, there is a pair of springs on the throwout bearing that could be dry enough to squeak. And, I wouldn't worry too much about that. At 40-50 hours of use a year, it'll probably be about another 200 years before the wear would create an operating problem.
Each of the fingers on the pressure plate has a pivot point that could possibly squeak, but the 200-year rule would apply there, too.
On the other hand, if you want to split the tractor to diagnose/fix, it's not that bad if you can support the front and back halves when they come apart, and if you have patience and a little common sense to undo and re-do a bunch of bolts and screws and whatever. Read and follow the manual.
Good luck.
reb
[Reply]  [No Email]
rustyfarmall
08-07-2012 06:23:21
67.55.162.174
 Re: 641 Clutch Throw-Out Bearing in reply to reb-in-pa, 08-07-2012 04:43:50
A throw out bearing that is dry of grease will squeal like a pig when the clutch pedal is depressed. No questions about what needs fixin' when you hear that sound.
[Reply]  [No Email]
showcrop
08-07-2012 04:31:07
75.67.231.80
I would say that it squeaks because it is seized and not turning, so the fingers are riding on the surface. I wouldn't worry about using it for the rest of the season, because you will be replacing the fingers with the clutch, but I would get after it once you are done for the season. Splitting these is not a big job. Plan on new trans input bearing and seal while in there. Some one posted a few months back about using a trailer jack with a fabbed bracket to hold up the back end and make it easier to push it back. I plan to do that for my next split. get a manual and there will be plenty of advice here.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
