Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: FORD 3000
[Return to Forum]
kwrules
08-04-2012 18:19:08
63.248.51.153
i have a 1970 ford 3000 s o s / i just bought it / i can not find the s o s fill plug ? is the rear end (diff) and three point oil sepaerated / and is the oil type the same? thanks for any help ut
[Reply]   [No Email]
Sean in PA
08-05-2012 11:02:19
71.224.102.32
 Re: FORD 3000 in reply to old, 08-04-2012 18:19:08
Rear end (differential) and 3 point hydraulics is one sump. Fill hole for the rear end/3 point hydraulics is on top of rear axle center housing under where you right butt cheek is when you're sitting on the tractor. Level check hole is on the right side near where you right foot is when you're sitting on the tractor.
Transmission is a separate sump no matter what transmission you have on a 3000. The S-O-S transmission has a single hole on the right side near where the trans housing bolts to the rear axle center housing. That single hole is for filling and for checking the level of the fluid.
Both the rear end/3 point hydraulics sump and the S-O-S transmission sump should get a UTF that meets the Ford/New Holland M2C134D specification.
You should get yourself an owner's manual, as all of this is covered in there, along with pictures of where the fill and level check holes are. If you aim to do more than regular maintenance yourself, a service manual is recommended as well..
[Reply]  [No Email]
Tequila
08-05-2012 08:03:17
70.196.202.180
 Re: FORD 3000 in reply to kwrules, 08-04-2012 18:19:08
Same fluid works in both however they are seperate systems. SOS trans. Is filled thru the fluid level plug located on right side midway on trans. Case.
[Reply]  [No Email]
jc okla
08-04-2012 19:30:32
74.197.231.200
I have a 3000 diesel. the fill plug is on the left side behind the seat. hyd and trans are together. there is a plug that is located on the left side about half way down in trans you take it out and fill from top till it runs out................... dang I ment to say the right hand side for both
[Reply]  [No Email]
Bern
08-04-2012 22:40:34
66.218.202.101
 Re: FORD 3000 in reply to jc okla, 08-04-2012 19:30:32
Don't think so. There is no fill plug on an SOS trans, and it is also separate from the rear axle.
[Reply]  [No Email]
Bern
08-04-2012 19:21:00
66.218.202.101
There is no fill plug, this is to keep you from overfilling it. You fill it through the check plug hole. Trans uses NH 134 hydraulic fluid, just like the other sumps do.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
