| Ford Tractors Discussion Forum |
Topic: Ford 3600 Diesel Priming fuel system Help!
[Return to Forum]
| Author |
[Modern View]
| Matt In NM
08-03-2012 23:00:03
173.190.151.83
So Long story short. My 3600 developed a small hesitation at wide open throttle so I quickly found out I had a dirty fuel tank and I cleaned it to where now I get a strong stream of fuel out of the tank as before it would barely drip. Replaced the filter and now I can"t get fuel to come out on the top of the filter housing bleeder plug screw. I have a good strong steady stream coming from the tank line but nothing at that bleeder screw on the filter housing. Am I missing something? Thanks for any ideas. |
[Reply] [No Email] | |
| RodInNS
08-04-2012 06:41:17
216.118.158.123
Re: Ford 3600 Diesel Priming fuel system Help! in reply to Matt In NM, 08-03-2012 23:00:03
| | Is the tank full? If the tank is near empty the fuel level is probably below the bleed screw or just above it... and with filter resistance it doesn't want to bleed. Regardless... just fill the tank. Bleed the filter. Bleed the pump body. Then open all three injectors and crank at WOT until you get good steady shots of fuel at at least two injectors. Then close them up and start. Rod |
| Matt in NM
08-04-2012 10:07:16
139.55.235.62
Re: Ford 3600 Diesel Priming fuel system Help! in reply to RodInNS, 08-04-2012 06:41:17
| There is about 3/4 tank of fuel. When I drained it I got out over ten gallons. I used about a gallon to help rinse out the tank so I know there is at least 10 gallons in therte or close to it. I'm thinking that's enough. My next thing is I'm going to make sure I put the o rings where they belong on the filter. It does take big orings and one tiny one and one small one where the hole of the filter mates witht he part that goes into it on the filter housing right? The only other thing is maybe some dirt got into the filter housing on top so I'm going to remove it and make sure it's free flowing towards the outlet. Thanks |
| RodInNS
08-04-2012 11:25:09
216.118.158.123
Re: Ford 3600 Diesel Priming fuel system Help! in reply to Matt in NM, 08-04-2012 10:07:16
| I'd still fill the tank... stranger things have happened than to fight something simple like that. The orings... the smaller flat one is for the bottom of the filter; the larger flat for the top. The thumb sized round oring is for the center of the filter housing where the filter contacts it. Most NH filter kits also have two tiny ones... one for the shoulder of the housing retainer bolt and one for the drain/thumb screw. If you're not getting much fuel into the filter with 3/4 tank I'd say there's an obstruction there somewhere, mabey in the line. Compressed air will blow it out. Just remove it from the tank first...Rod |
| Matt in NM
08-04-2012 11:44:42
139.55.235.62
Re: Ford 3600 Diesel Priming fuel system Help! in reply to RodInNS, 08-04-2012 11:25:09
| Update! It turned out I had one of the big flat orings in the groove where the fuel goes into the fuel filter. After I corrected the problem I got it running like a top in 5 minutes. Thanks for the input! Problem was the Wix filter comes with three of the big flat oring seals where you only need two therefore caused me some confusion. Thanks! |
| hurleyjd
08-04-2012 06:27:09
69.46.54.90
| Have someone pull you off will start in about fifty feet. Put tractor in high gear and keep clutch depressed. After the tractor starts rolling well release the clutch and the tractor will start. Then wave for the puller to stop. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
