| Author |
[Modern View]
| Will Gumbert
08-03-2012 19:26:16
96.239.159.248
Does anyone know where I could get a pair of stabilizer bars for my 961 similar to the one shown on this 2000 row crop tractor? Note that they are mounted on the inboard side of each lift arm and go to pins on a bracket welded to the bottom of the axle center housing. This one is made of 1/4 inch plate and is roughly 15 inches long. The flat ends are bent at about 45 deg angle. I'm not sure if the owner made these or if they are available somewhere. |
| Lynn Patrick
08-06-2012 07:15:54
208.95.68.80
Re: Stabilizer bars for Ford 961 in reply to Will Gumbert, 08-03-2012 19:26:16
| I have a set I made out of 1/4" x 1 1/2" for my 960 that I would gladly trade for your fender bolt mounted brackets! They work but as has been said are a bear to use. |
| roman candelaria
08-05-2012 10:34:46
67.86.38.240
| I have those short ones that are on the blue tractor made at a shop where they make springs for trucks, make sure your pattern is correct cause you can't bend them to fit (spring steel) |
| johnw (OR)
08-04-2012 20:14:05
50.53.139.70
| Soundguy emailed me a patern for them, made them worked great. |
| soundguy
08-04-2012 14:48:38
107.41.212.253
|    make em. I made a set for some of my rowcrops using patterns from another rowcrop i had. as dean said.. making a conversion may be easier. i made up a conversion for my 4000rc i mow with. made hitching a mower and back blade easier... |
| Will Gumbert
08-04-2012 15:44:16
96.239.159.215
Re: Stabilizer bars for Ford 961 in reply to soundguy, 08-04-2012 14:48:38
|  Thanks, Soundguy for the detailed post. What you did, I think, is similar to the brackets that are already on my tractor (see photo -sorry for the poor quality cell phone photo). Thing is, as this tractor is mainly for show, some day I hope, I would like to do the inboard bars just for looks. The only thing they will really do is keep the lift arms from flopping around when moving the tractor. So, I may be able to make them myself out of 1/8 in plate which I think I can bend. Thanks so much! |
| soundguy
08-04-2012 16:00:52
184.247.233.228
Re: Stabilizer bars for Ford 961 in reply to Will Gumbert, 08-04-2012 15:44:16
| for show, 1/8 will work.. but in use.. you want 3/8 a set of stab bars from tsc, a torch and vice will make them... but yeah.. the drop bracket is about the same deal as I buzzed up... |
| MarkB_MI
08-04-2012 08:52:21
66.87.7.142
| Call your CNH dealer. You need part number 230917. Listed as a "sway bar". If you ask the counter guy for a stabilizer bar, he won't have a clue how to find it, but the part was still available a few years ago. |
| Will Gumbert
08-04-2012 11:37:55
96.239.159.215
Re: Stabilizer bars for Ford 961 in reply to MarkB_MI, 08-04-2012 08:52:21
| Thanks, Mark. I'll give that a try, although every time I ask him (the CNH parts guy) for a price I cringe. Last week I paid $102. for a new fuel line for my 4 cyl gas 4000. Yikes. |
| MarkB_MI
08-05-2012 05:43:13
66.87.4.110
Re: Stabilizer bars for Ford 961 in reply to Will Gumbert, 08-04-2012 11:37:55
| | I don't recall what I paid for mine, but CNH sure isn't bashful when it comes to pricing their parts. Consider just buying one bar. I seldom hook up both of mine because it's too much aggravation. They're so short it's tough to get the second bar in place. Even carrying my flail mower on rough ground, the single bar is sufficient. I doubt if you can get away with using a single bar if you have a set fabricated, though. The OEM bars are made of pretty tough stuff. |
| Fordfarmer
08-04-2012 11:45:13
184.158.2.196
| A local machine shop took measurements off the set I had, before I sold them. Don't know if he's ever gotten around to making any or not. Could give him a call if you can't find any anywhere else. (715)532-0840. He could UPS them to you. |
| Will Gumbert
08-04-2012 15:48:49
96.239.159.215
Re: Stabilizer bars for Ford 961 in reply to Fordfarmer, 08-04-2012 11:45:13
| Thanks Fordfarmer. I might give him a call. Depends on what he would charge compared to other options. |
| awhtx
08-04-2012 08:03:51
64.185.31.67
| I hope the bracket is not welded to the bottom of the center housing! The bars attach to a special version of the swinging drawbar anchor and it supposed to be bolted to the bottom of the center housing with 4 bolts- 5/8" coarse thread as I recall. |
| Will Gumbert
08-04-2012 11:43:49
96.239.159.215
Re: Stabilizer bars for Ford 961 in reply to awhtx, 08-04-2012 08:03:51
| Yes, you're probably right, they're bolted to the housing. I was too lazy to crawl under there and look. |
| Will Gumbert
08-04-2012 05:58:57
96.239.159.248
| Yes, I can see how that would be the case. One idea might be to see if I could find a pair of those short adjustable units as used on modern compact tractors. That might make it easier to do, but wouldn't look original. This tractor is more for show than work, I mainly don't like the lift arms swinging back and forth with only the sway chains. |
| Will Gumbert
08-04-2012 04:50:39
96.239.159.248
| Thanks, I kinda thought they were OEM parts that are not made today. My tractor does have two large brackets mounted on the underside of the axle on the fender mounting bolts. I thought these were for stabilizer bars but was not sure. I like the idea of the inboard bars though. I may be able to make a sample out of thin metal and then take it to someone to have thicker ones made. Thanks again for the info. |
| Dean
08-04-2012 05:39:17
67.172.15.77
Re: Stabilizer bars for Ford 961 in reply to Will Gumbert, 08-04-2012 04:50:39
| | The OEM inboard bars are neat and tidy but considerably more difficult to install and remove than the long outboard bars as used on the utility model tractors and row crop tractors that have been fitted with conversion brackets, which are much different than the brackets used on utility tractors. Everything must be just about perfect in order to fit the bars after hitch up. Dean |
| Vito
08-04-2012 04:19:04
75.130.91.54
| I got a set from Ken @ Long Lane tractor.You might want to call him as he deals in quite a few of these tractors.HTH Vito |
| showcrop
08-04-2012 03:38:11
75.67.231.80
| I have two tractors that have those. Given one for a pattern, it should be very easy to have a fab shop make them for you or even make them your self if you are equipped. |
| Scott D Orbaker
08-03-2012 22:07:13
66.67.10.232
| | Will, As Dean said ,they are OEM items. 46 years ago a neighbor of ours bought a 960 at auction. It had those short bars on it and he changed them over to long ones that went from brackets mounted under the fenders to the outside of the lift arms and connected where the 3 pt drawbar attached. Scott |
| Dean
08-03-2012 20:34:43
152.216.3.5
| | The stabilizer bars on the pictured tractor are OEM units. Stabilizer bars for 7/9xx tractors are hard to find. I sold my spare set a couple of years ago. Dean |
