| Ford Tractors Discussion Forum |
Topic: Speaking of bush hogs...
[Return to Forum]
| Author |
[Modern View]
| Doug (OH)
08-02-2012 19:25:17
76.241.104.36
I have a 60" Howse that has a stuck nut on the one blade. Soaked it a couple times with sea foam. This thing will not budge! I'm thinking the next step is to heat the nut... or just remove the hub and cut the dang thing off. I guess my question is, with the blade being loose, I want to tighten it to eliminate the wobble. My thought is that it over time, it will widen that hole and I'll need a new hub. Is this a safety issue? Suggestions? Comments? Thanks in advance. Doug |
| Coff52
08-03-2012 07:50:36
71.30.235.71
Re: Speaking of bush hogs... in reply to Doug (OH), 08-02-2012 19:25:17
| I had one on my lawnmower this year same way. I never had one I could not get off but this one would not even move with an impact wrench. Went to the neighbors and borrowed his torch, put a little heat to it and it finally broke loose. I thought I was going to have to cut it off as well. Finally got it off and I replaced it with a new one. |
| Doug (OH)
08-03-2012 06:13:09
98.103.149.138
| Thanks, everyone. I"ll be looking at it again this weekend. Doug |
| Ultradog MN
08-03-2012 04:57:32
65.103.0.245
| Bush Hog is a registered trademark. A Howse in not a Bush HogŪ. |
| soundguy
08-02-2012 21:48:50
184.4.151.135
| | i hate re-using those shouldered bolts and nuts on hog bladesunless they are spanking new like. torch it off and be done with it. |
| Dean
08-02-2012 20:41:39
152.216.3.5
| | Definitely a safety issue. Almost certainly the bolts need replacement. Remove and replace. Use heat or other techniques if necessary. Dean |
| Royse
08-02-2012 19:53:13
69.36.49.151
| Soak it with penetrating oil. PB Blaster or Kroil are my favorites.
Heat may also help.
My guess is that if it has been run while loose, the nut is not the only problem.
The shaft/bolt that it mounts to and the blade are probably already worn as well. |
| Doug (OH)
08-02-2012 20:06:03
76.241.104.36
Re: Speaking of bush hogs... in reply to Royse, 08-02-2012 19:53:13
| Hi Royse, I suspect you're right. Well, I've worked it hard that last few years, so I guess it earned the right to be a little tired. Thanks much for the info. Doug |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
