Topic: Tire problem
[Return to Forum]
| Author |
[Modern View]
| flyingace
08-02-2012 16:14:17
208.101.209.179
I have a '66 3000 with a front tire that keeps going flat. The tire/tubes are new, but the wheel is 46 years old. The tube seems to be getting pinched between the rim and tire bead when the tractor is in use. At least that's where the last hole in the tube was.
The recommended tire size is 6-6.50 X 16, but the old tires were 7.50 X 16. The old tires rubbed the radius rods during turns, so I got 6.50s.
Is there a possibility that these wheels were designed for 7.50 tires? Does anybody know the actual width of the standard (6-6.50) rim? I'm wondering if the wheel is too wide for the tire and that's why I'm having this problem.
Any other suggestions greatly appreciated.
This post was edited by flyingace at 16:14:41 08/02/12. |
| Royse
08-02-2012 17:34:45
69.36.49.151
Re: Tire problem in reply to flyingace, 08-02-2012 16:14:17
| Like SoundGuy said, putting them on with the tube inflated is one of the best tricks I've learned.
Keeps you out of a lot of trouble with pinched tubes! |
| soundguy
08-02-2012 17:08:25
184.246.1.233
| | if the tire profile loks good on the rim and not wider at the base than at the start of the tread rim width is ok getting the tube out from under the tire bead is just one of those things that comes with time and learning, doing your own tires. I usually get my tubes in while the one side of the tiree is still over the rim, then inflate the tube to expand and seat a bit.. then deflate it a bit till soft but filled.. this keeps it from folding and getting under the tire bead as you seat the other side of the tire withj your spoons. be sure not to stab too deeply and pinch them either. |
| flyingace
08-02-2012 17:47:54
208.101.209.179
Re: Tire problem in reply to soundguy, 08-02-2012 17:08:25
| Quoting Removed, click Modern View to see
The tire sidewall sticks out beyond the rim. I don't think you would see that if rim was too wide.
Thing is, these installs have all been done by a tire shop. I asked them each time if it could be they pinched the tube, and they say 'no way'. I even watched the last one, and I didn't see it pinch. Still it goes flat.
They haven't made me pay for these repairs, so they aren't doing this on purpose.
I think I will do this one myself. I've changed motorcycle tires before, so I'm hoping this won't be too much worse. |
| soundguy
08-02-2012 17:51:32
184.246.1.233
Re: Tire problem in reply to flyingace, 08-02-2012 17:47:54
| | if the sidewall bows out the rim may be a tad small.. but you can usually get away with a size or two.. tire shop or no.. if they are installing it.. it goes flat.. hole is in bead when they dismount.. then guess what. proof is there.... |
| flyingace
08-02-2012 18:09:57
208.101.209.179
Re: Tire problem in reply to soundguy, 08-02-2012 17:51:32
Thanks SG. I guess the old saying applies 'if you want it done right, do it yourself'. |
| soundguy
08-02-2012 18:16:58
184.246.1.233
Re: Tire problem in reply to flyingace, 08-02-2012 18:09:57
| flyingace
08-06-2012 16:46:57
208.101.209.179
Re: Tire problem in reply to soundguy, 08-02-2012 18:16:58
Just as a follow up to this, I patched up the tube and re-installed by hand, following the advice about semi-inflating the tube. Guess what, been 3 days including a little work and it's still holding.
I did grind down some pretty sharp burrs on the rim before installation, so maybe that was the root of the problem. However, since this has happened to BOTH tires, I have to wonder about the tire shop. You would think a shop specializing in ag tires would know how to work with an inner tube! |
| soundguy
08-07-2012 05:29:05
107.41.216.146
Re: Tire problem in reply to flyingace, 08-06-2012 16:46:57
| | i agree with btd.. it's the workers. good ones are good.. bad ones are bad. you can now see that just a lil care can have good results as you installed yours with a few tips and no issues occured. good luck soundguy |
| BDT in Minnesota
08-06-2012 17:43:50
66.87.7.209
I have watched a few "tire shop guys" that were not the"pick of the litter"
Equgor is one of them... a week after "free installation" of new steer tires on one of my Petes, I noticed what looked to be a crack... Both Aluminum wheels were cracked.... I didn't say anything; just went back and watched Equgor mount a steer tire on a truck... He hand started all ten lugnuts, then, without pushing the wheel up against the hub, took his air wrench and hammered the first lug nut tight with a big BANG as he broke another wheel.. He went to the next lugnut continued to tighten in a circle.. Tightend each lugnut once.... Give Equgor a tire hammer and he will mash a rim for free..
I don't shop there anymore; their "free" is just too expensive.... I mount my own tires.... SADly Equgor seems to have allot of cousins who also work in tire shops.....
A Good Tire Tech; Like any other service personell, should be highly valued and recommended... |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
