| Ford Tractors Discussion Forum |
Topic: report on woods 6500 hoe on my ford 850
[Return to Forum]
| Author |
[Modern View]
| soundguy
08-02-2012 05:13:45
173.105.131.219
finally got some use out of my woods 6500 hoe.since I got it last year it's been at my stepdads place doing work for him ;) back when we got it, I was considering that hoe or one of those tow behind models at northern tools / harbor freight. after looking at the use that's been done and seeing both ( have a local northern tools with 1 in stock ).. i think I easilly have made the correct decision going with the woods 3pt hoe. blew the pressure line on the pump but it had been kinked and I knew it was gonna go eventually. 32$ later and it was up and running again. gug out some old drainage tile at a friends house and then pulled out a hedge row where he was going to finish up some dog fencing. his dogs dig bad so we were putting in 6' chain link burried 1' to make a 5' fence above ground. hoe worked perfectly. I like having the 90' side swing arc for dumping dirt.. the hf/nt model only has a 60' side arc.. plus is run off a 2.7gpm pump on a 8hp lawnmower engine.. :) kinda nice having it on a tractor to maneuver back in to a place.. even nice mounted on a tractor with a loader. :) subframe and beefed up top cover mount supports I built worked ( and has been ) working perfectly. |
[Reply] [No Email] | |
| Greg Wolodkin
08-03-2012 19:57:55
96.252.121.186
Re: report on woods 6500 hoe on my ford 850 in reply to TONY JACOBS, 08-02-2012 05:13:45
| Glad to hear it's working out! |
| soundguy
08-04-2012 14:01:04
107.41.212.253
Re: report on woods 6500 hoe on my ford 850 in reply to Greg Wolodkin, 08-03-2012 19:57:55
| | i knew she worked.. my stepdad has had her all winter. he used her a bunch.. then let her set. bat died.. I charged the bat, draind a cou of old gas to clear the carb and lines.. add a couple gallons new and some atf.. ran paper thru the points.. cleaned the plugs with some paper and spray cleaner and she banged right off.. then blew a hose. replace dthat and a couple gal hyds fluid and she dug good. first i've actually got to work with her. can't complain.. stepdad did pay for most of the hoe.. only fair that he got to use it first.. :) |
| alinark
08-03-2012 04:41:10
70.178.17.197
Re: report on woods 6500 hoe on my ford 850 in reply to soundguy, 08-02-2012 05:13:45
| soundguy been meaning to tell you i have my 7500 mounted to my 63 2000 am surprised at how well it fit up i have to figure out a solution to tying in the front mount on the subframe i'll post pictures when finished al |
| soundguy
08-03-2012 15:45:46
107.41.43.217
Re: report on woods 6500 hoe on my ford 850 in reply to alinark, 08-03-2012 04:41:10
| | yep.. this 6500 is slightly undersized for an 850.. but I like that. built in margin of safety. do tie in / make some sort of extra bracing.. makes all the difference. I dug a few test holes just using the 3pt setup.. then welded in the extra bracking and support cage for the center section and top cover and tied in as many bolt on places as I could to the axle trumpets sides and the top cover and center section as I could. don't ignore the 3pt rockert connection either. stabilize it so it does not beat up the draft mechanism. I made a slip cage that fit over my 3pt rocker and holds it rigid.. uses a long pin to go thru cage and rocker and toplink on hoe. soundguy |
| Jim in Ma.
08-02-2012 12:04:59
72.70.109.209
| Glad to hear that. I use one on my small Kubota, Mostly to dig graves in tight places. Sure it is slow but still a lot better than a shovel. Most times I dump the dirt into a lawn trailer to haul away. |
| soundguy
08-02-2012 14:53:49
173.107.232.218
Re: report on woods 6500 hoe on my ford 850 in reply to Jim in Ma., 08-02-2012 12:04:59
| i have pigs, horses and cows.. so having the ability to dig a large grave comes in handy.. hadn't thought about keeping a 10cf wheelbarrow nearby.. have tarped the ground before... |
| showcrop
08-03-2012 04:34:43
75.67.231.80
Re: report on woods 6500 hoe on my ford 850 in reply to soundguy, 08-02-2012 14:53:49
| Quoting Removed, click Modern View to see
When we had sheep I used to dig a grave every fall just in case. I would throw two bales of hay in it, so even if it got to twenty below during lambing I was ready. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
