Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: My first tractor - Help!
[Return to Forum]
Jetbird
07-29-2012 19:42:05
68.112.236.249
Ok, so I bought a 1967 Ford 3400 gasser with a loader for $2600. I was overexcited and I bought it without looking it over thoroughly.... So I get it home and I pull the dipstick and realize that the oil is a milky tan color, meaning water in the oil. The tractor did not smoke when it ran. There were no bubbles in the radiator or oil in the radiator. I found out the breather tube was plugged and figured the water got in the engine by condensation from only being run for short periods of time. So I found some advice online that said drain the oil, fill crankcase with diesel fuel, disconnect sparkplug wires, turn engine over 10-15 seconds to mix it all up, and drain out. I did this twice, then refilled with oil, ran it a few minutes, and parked it in the garage. The oil looked fine on the dipstick, so I figured I was OK. Now it's 2 weeks later and tonight I pulled the drain plug and milky tan oil came out. Uh-oh. The oil on the dipstick looks fine still. What does this mean? I thought since I had no smoke when it ran and no bubbles in the radiator that my head/head gasket were OK. Do I have a rust-through in the water jacket?? Or is this water left over from before somehow? Help! :(
[Reply]   [No Email]
WGWKy2
07-30-2012 15:05:32
98.23.19.190
 Re: My first tractor - Help! in reply to Jetbird, 07-29-2012 19:42:05
I drained the oil out of mine and left a cup under it overnight. The next morning the cup had water in it as running over, hole in the cyl wall. Had it bored and a sleve put in, but you have better luck than me, I hope!
[Reply]  [No Email]
soundguy
07-30-2012 07:00:45
173.104.251.58
i'd fill the rad with plain water.
change oil with walmart 15/40 and add in some seafoam to oil.
run her all around ( get warm ) and then let set
check and post back.,
[Reply]  [No Email]
Ultradog MN
07-30-2012 05:14:49
65.103.0.18
I would let it sit for a few days and see if the water will de-emulsify from the oil. Then crack the oil drain plug and if there is water/anti freeze in it it will dribble out first.
I would not use diesel in it. Post back with your results.
That is a very good tractor and worth getting to the bottom of this.
[Reply]  [No Email]
wisbaker
07-29-2012 23:25:37
207.118.135.5
Think them good thoughts- can you take it out and work if for a few hours? If
you're real lucky maybe it's still condensation in the oil, work it long and
hard enough to burn the condensation off and see if it comes back, might also
check the crankcase breather. Try running a compression test and see if that
tells you anything. But be prepared to do a head gasket,if you do it yourself
it's a lot of work but not really that much in parts unless you end up breaking
or replacing a bunch of other parts on your way to and from the head gasket.
[Reply]  [No Email]
old
07-29-2012 20:01:46
209.86.226.19
Well since I only know a little bit about that tractor all I can say is good chance it has a bad head gasket. Many times you will not see signs of it in the radiator but will find coolant in the oil. One way to know is if you park it say for a week then slowly open up the drain plug watch for antifreeze dripping out before you get the oil drain plug all the way out.
[Reply]  [No Email]
Shaun Wallace
07-29-2012 19:59:06
184.79.84.3
It will take many oil changes to get all the condensate out of crankcase if that is the only problem. Pull the valve cover and clean it up will go a long way in stopping build up in pan.
[Reply]  [No Email]
Jetbird
07-29-2012 20:10:52
68.112.236.249
 Re: My first tractor - Help! in reply to Shaun Wallace, 07-29-2012 19:59:06
Thanks for the reply. So I pull the valve cover and just dry it off as best I can with rags or compressed air? Should I leave the valve cover off for a while to let the moisture escape? Would you recommend another diesel flush? Also, I have a kit to detect combustion gas in the radiator, maybe I should try that out. I will have to reinstall the radiator and put on the new exhaust header first.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
