| Ford Tractors Discussion Forum |
Topic: 850 PTO assembly end play
[Return to Forum]
| Author |
[Modern View]
| Billy NY
07-27-2012 16:27:06
67.248.100.3
I've had a leak on the pto shaft for awhile, and upon taking a look at it, I noticed there is about 1/2" end play, side to side is tight, after reading some old posts here, and the ford shop manual, the oil seal as shown looks typical for a driveline, and I assume you can pull the assembly, rebuild as needed, would like to fix the leak and the end play, never had one of these out before, any special tools needed, and or tricks to dealing with the repair ?As is it still performs fine,just leaks engages easily, stays engaged, no problems yet, so maybe I caught it in time, shop manual says nothing about end play in these. |
| Billy NY
07-27-2012 16:57:40
67.248.100.3
Re: 850 PTO assembly end play in reply to Billy NY, 07-27-2012 16:27:06
| | Upon further investigation, I see the shaft and housing complete, so you can replace it in whole, if I see this correctly ? (just had to see a photo of the part) Time for a fluid change too, so drain em down, and I had been using 90 wt in the differential, and recall a GL type not to use, bronze bearing incompatible, anyone recall ? I am not sure if the seal in the back is allowing the fluids to mix, not sure how you would tell and or what happens if 90wt mixes in from the rear ? I would also assume, because there are no other problems with the pto operatiopn, this would be easiest, can shelve the old one for later rebuild |
| soundguy
07-27-2012 19:02:29
107.41.28.95
Re: 850 PTO assembly end play in reply to Billy NY, 07-27-2012 16:57:40
| | trans and diffy CAN use a 80w90 gl5 oil.. no yellow metal to worry about really. the hyds need utf. if your diffy to hyds seal that the pto passes thru leaks.. use utf in all sumps. the pto is easy to remove. 4 bolts and the shaft and bearing carrier slide out after you drain the 2 rear sumps. very likely a seal wear ring has moved on the shaft, or a split ring has popped out of a groove or snapped. easy to rebuild.. I wrote an article on it in the N news a while back. figure 30m to rebuild with parts on hand. ( new pto gasket, new seal, new beraing and new wear ring.. 40$ or so of parts if you do the bearing and wear ring..) or you can repalce it for about 120$ |
| Billy NY
07-28-2012 09:54:50
67.248.100.3
Re: 850 PTO assembly end play in reply to soundguy, 07-27-2012 19:02:29
| | Right, GL-5, I was pondering this before, reading old posts etc., I'm not sure if that seal is leaking or not, any way to tell ? Does one gain and you can check when pulling the plug or dipstick? I was looking for your article over on that site, not sure where to find it or was it just in their printed magazine, sounds like a minor task to rebuild, or replace, I'll probably opt for the bolt in for now, just need to source it, I saw quite a few on ebay , some had the bushing on the far end others did not, need to take a closer look at that. |
| soundguy
07-28-2012 16:01:19
107.41.34.218
Re: 850 PTO assembly end play in reply to Billy NY, 07-28-2012 09:54:50
| | easy to repalce. almost as easy to rebuild.. your call.. hyd sump gets a lil low.. diffy gets a lil high |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
