Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Power Steering Issue - 660 / 641
[Return to Forum]
Kurt-NEPA
07-20-2012 02:54:00
70.44.245.96
I've been adding power steering to my 660. I found a donor unit off a 641, cleaned it all up, bought new hoses, filter, belt and mounted everything on my 660. I just finished bleeding the air out and found a problem. The steering works fine turning one way, but is hard turning other. Almost harder than without power steering. Seems like it fighting me just a bit.
I disconnected the cylinders from the drag link, the right one acts as I would have expected, but the left one seems strange. As I turn just a little to the right, it extends completely. Any turn to the left and it retracts, but slowly.
I am thinking I have some valve problems. Before I pull the dash off again, I thought I ask here for some insight.
Thanks,
[Reply]   [No Email]
Kurt-NEPA
07-24-2012 07:11:59
70.44.245.96
 Re: Power Steering Issue - 660 / 641 Update in reply to Kurt-NEPA, 07-20-2012 02:54:00
Update. I finally found some tractor working time and pulled the PS Valve off the steering gear. Here is what I found.
Tony, you were right on the mark - one broken spring. Parts are on order for delivery Thursday, That gives me 3 days to figure out how to put this back together. Every thing just fell out as I lifted.
Time to hit the books. At least everything looks nice and clean. That's a relief.
Thanks for all the help,
Kurt
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 06:50:44
70.44.245.96
 Re: Power Steering Issue - 660 / 641 in reply to Kurt-NEPA, 07-20-2012 02:54:00
So that confirms it Tony - something is up. We'll see. Thanks
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 06:29:57
70.44.245.96
Makes me nervous too Tony. That price is too low compared to the last time I looked. Messick's didn't indicate that the springs were aftermarket, so maybe CNH just outsourced them to the "land of almost right" I think I'll order them and see what shows up. They are showing 3-5 day shipment, so it sound like they will come from the CHN warehouse. The seals and o-ring are in stock.
Sounds like I have several days to tear this thing down.
[Reply]  [No Email]
TONY JACOBS
07-20-2012 06:46:42
205.188.116.9
 Re: Power Steering Issue - 660 / 641 in reply to Kurt-NEPA, 07-20-2012 06:29:57
Hello Kurt , My local Dealer just confirmed the price was that low also , so I ordered some more to see where they are made . Thanks Tony
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 06:18:36
70.44.245.96
The price surprised me. Last time I looked I think they were $44 each. Maybe I better order quick before they change their minds.
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 05:43:24
70.44.245.96
Thanks Tony - I just checked, Messick's price is $17.84 X 3. So that's better than Jerry's price.
[Reply]  [No Email]
Ultradog MN
07-20-2012 06:10:40
70.56.166.240
 Re: Power Steering Issue - 660 / 641 in reply to Kurt-NEPA, 07-20-2012 05:43:24
I wonder why I got gouged so bad.
I just bought 3 of them and they were over $100.
At $18 each Tony might be right.
If you want to get rid of your old ones send them to me. I'll keep them as spares as I have no qualms about reusing them. The same springs and plungers fit both 4 cyl and 3 cyl tractors btw.
[Reply]  [No Email]
TONY JACOBS
07-20-2012 05:59:44
205.188.116.9
Hello Again Kurt , That sound awfully cheap , the last box I did for Mike they were around Jerry's price and still USA MADE , I figured they would have gone up a little by now . If you get them in and they are made in China I would be hard pressed to use them considering their track record . Thanks Tony
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 05:29:15
70.44.245.96
Tony - Are you talking about spring number 39 in Ultradog's diagram?
[Reply]  [No Email]
TONY JACOBS
07-20-2012 05:38:15
205.188.116.9
 Re: Power Steering Issue - 660 / 641 in reply to Kurt-NEPA, 07-20-2012 05:29:15
Hello Kurt , YES , I am .
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 05:16:22
70.44.245.96
Hi Tony,
I'll order the springs too. I don't want to do this twice.
It was great to meet you a few weeks ago at Mike's. Hope the rims worked out well for you.
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 04:23:48
70.44.245.96
Thanks for info and diagram Ultradog. That really helps. I'll get the o-rings and seals on order. I'm hoping that's all I need. I've got way too much money in this tractor already.
As for the direction of movement, I'm a little foggy on the whole thing right now. You are correct that its a little hard to get your head around it. It seems to me the cylinders were moving correctly, But I'm going to check it again before I start pulling the dash and battery tray. At least I didn't put the hood back on yesterday
As with all used equipment, I expected some problems. The good news is no leaks. The pump seems good as do the cylinders. If all I have to do is clean up the valves, I'm happy.
Thanks
[Reply]  [No Email]
TONY JACOBS
07-20-2012 05:05:58
205.188.116.9
 Re: Power Steering Issue - 660 / 641 in reply to Kurt-NEPA, 07-20-2012 04:23:48
Hello Kurt , Make sure you order three of the little springs also , they are expensive but it will keep you from tearing it back apart when they break later which they always do . Thanks Tony
[Reply]  [No Email]
Ultradog MN
07-20-2012 05:28:03
70.56.166.240
 Re: Power Steering Issue - 660 / 641 in reply to TONY JACOBS, 07-20-2012 05:05:58
I disagree Tony. I have reused them several times and they are still going strong. At $34 each X3 I would not just replace them.
[Reply]  [No Email]
TONY JACOBS
07-20-2012 05:52:49
205.188.116.9
 Re: Power Steering Issue - 660 / 641 in reply to Ultradog MN, 07-20-2012 05:28:03
Hey Jerry , I forgot to add how many bearings # 31 that I have had to replace in my tractors alone at $200 plus a pair . The seals like you said are a common leak problem as are the sector shaft seals which I always replace too so I can use gear oil and not grease in them as they had when new . Also don't forget out here EVERYTHING is a loader tractor and don't usually get much mercy shown to them when the box is bad it get very expensive in a hurry . Thanks Tony
[Reply]  [No Email]
TONY JACOBS
07-20-2012 05:36:36
205.188.116.9
Hello Jerry , As many of these boxes as I have rebuilt and as many of the springs that have failed I replace them because it is cheap insurance from pulling it back apart . How many cycles do you think that spring has gone through in the last 50 yrs ? I just recommend it from experience and do it to all of my tractors but my tractors are not show tractors that sit in the garage . Thanks Tony
[Reply]  [No Email]
Kurt-NEPA
07-20-2012 04:12:12
70.44.245.96
I hope its that simple Vito. Thanks for the reply
[Reply]  [No Email]
Ultradog MN
07-20-2012 03:47:10
70.56.166.240
Don't force it! It will break the little springs in the hyd block.
You state: "As I turn just a little to the right, it extends completely. Any turn to the left and it retracts, but slowly.
Shouldn't it be moving just the opposite?
It can be a bit confusing till you get your head around it.
If you haven't replaced the seals in the column I would do so now before you put all the tin on.
That upper column seal is a frequent failure item so doing it now is prudent.
Replace seals #28 & 44 and 2 Orings #32. While you are in there go ahead and dissasemble the hydraulic block and clean it in lacquer thinner.
I use white litium grease to reassemble.
They do get full of crud and rust and it is not a hard job to do.
If you get into trouble getting the plungers back in holler.
[Reply]  [No Email]
Vito
07-20-2012 03:23:25
75.130.91.54
It sounds like your diagnosis is correct as far as where to start
looking.
Vito
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
