1 1 EAE6375B Flywheel Assy., 9" Single Clutch, Prior to S/N 14257, No Longer Serviced, Years: 01/01/1953-12/31/1957
1 1 B7P6375B ENGINE FLYWHEEL Flywheel Assy., 10" Single Clutch, Prior to S/N 14257, No Longer Serviced, Years: 01/01/1955-12/31/1957
1 1 EAF6375D Flywheel Assy., 9" Double Clutch, Prior to S/N 14257, No Longer Serviced, Years: 01/01/1955-12/31/1957
1 1 311244 WHEEL Flywheel Assy., 10" Single Clutch, After S/N 14256, No Longer Serviced, Start Year: 01/01/1958
1 1 311428 SENSOR Flywheel Assy., 9" Double Clutch, After S/N 14256, No Longer Serviced, Start Year: 01/01/1958
1 AR C0NN6375D Flywheel Assy., 10 Speed Transmission Only, No Longer Serviced, Start Year: 01/01/1959
2 6 43070S36 BOLT Screw, Cap, HH, G8, Self-Locking, 7/16"-20 x 1-5/8", 10" Single, Start Year: 01/01/1953
2 6 PL PROCURE LOCALLY Bolt, HH, 9" Double, 7/16"-20 x .80, Start Year: 01/01/1955
3 1 9N6384 GEAR Gear, Flywheel Starting Ring, Start Year: 01/01/1953
4 1 8MB7600 BUSHING Bearing, Clutch Pilot, Use W/EAF6375B, NAA, NAB, Years: 01/01/1953-12/31/1954
4 1 81805417 BALL BEARING Bearing, Clutch Pilot, Start Year: 01/01/1953
5 4 86618939 CONNECTING ROD Rod Assy., Connecting, Start Year: 01/01/1953
6 4 EAA6207A BUSHING Bushing, Connecting Rod, Start Year: 01/01/1953
7 8 C1AE6214A BOLT Bolt, Connecting Rod, Start Year: 01/01/1953
8 8 C9AZ6212B NUT Nut, Connecting Rod, Replaces P/N C1TE-6212-A, Start Year: 01/01/1953
9 8 312026 LINER Liner, Connecting Rod, Standard, Start Year: 01/01/1953
9 8 312101 LINER Liner, Connecting Rod Bearing, .001 U/S, Start Year: 01/01/1953
9 8 312102 LINER Liner, Connecting Rod Bearing, .002 U/S, Start Year: 01/01/1953
9 8 C0NN6211A BEARING LINER Liner, Connecting Rod Bearing, .003 U/S, Start Year: 01/01/1953
9 8 312103 LINER Liner, Connecting Rod Bearing, .010 U/S, Start Year: 01/01/1953
9 8 312104 BEARING Liner, Connecting Rod Bearing, .020 U/S, Start Year: 01/01/1953
9 8 C0NN6211B BEARING LINER Liner, Connecting Rod Bearing, .030 U/S, Start Year: 01/01/1953
9 8 C0NN6211C BEARING LINER Liner, Connecting Rod Bearing, .040 U/S, Start Year: 01/01/1953
10 4 EAF6331A CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, Standard, Start Year: 01/01/1953
10 4 EAF6331B CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .001 U/S, Start Year: 01/01/1953
10 4 EAF6331C CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .002 U/S, Start Year: 01/01/1953
10 4 C0NN6331A CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .003 U/S, Start Year: 01/01/1953
10 4 EAF6331D CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .010 U/S, Start Year: 01/01/1953
10 4 EAF6331E CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .020 U/S, Start Year: 01/01/1953
10 4 C0NN6331E CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .030 U/S, Start Year: 01/01/1953
10 4 C0NN6331F CRANKSHAFT BEARING Liner, Front & Rear Main Bearing, .040 U/S, Start Year: 01/01/1953
11 2 EAF6342C CRANKSHAFT BEARING Liner, Center Main Bearing, Standard, Start Year: 01/01/1953
11 2 EAF6342D CRANKSHAFT BEARING Liner, Center Main Bearing, .001 U/S, Start Year: 01/01/1953
11 2 EAF6342E CRANKSHAFT BEARING Liner, Center Main Bearing, .002 U/S, Start Year: 01/01/1953
11 2 EAF6342F CRANKSHAFT BEARING Liner, Center Main Bearing, .010 U/S, Start Year: 01/01/1953
11 2 EAF6342G CRANKSHAFT BEARING Liner, Center Main Bearing, .020 U/S, Start Year: 01/01/1953
11 2 C0NN6342C CRANKSHAFT BEARING Liner, Center Main Bearing, .030 U/S, Start Year: 01/01/1953
11 2 C0NN6342D CRANKSHAFT BEARING Liner, Center Main Bearing, .040 U/S, Start Year: 01/01/1953
12 2 B3NN6336A SEAL PROTECTION Seal, Crankshaft Rear Main Bearing Cap, Hard Rubber, .010 O/S, Alternate W/C0NN6336A After S/N 138246, Start Year: 01/01/1953
12 2 C0NN6336A SEAL PROTECTION Seal, Crankshaft Rear Main Bearing Cap, Layed Rawhide, Alternate W/B3NN6336A After S/N 138246 on Model 601, Start Year: 01/01/1953
13 2 C0NN6701A SEAL PROTECTION Seal, Crankshaft Rear Oil, Steel & Rubber, Optional W/EBU6701A, Start Year: 01/01/1953
13 2 EBU6701A SEAL PROTECTION Seal, Crankshaft Rear Oil, Abestos & Jute, Optional W/C0NN6701A, Start Year: 01/01/1953
14 1 E2JL6300BA CRANKSHAFT Crankshaft & Plug Assy., Replaces P/N D1NL6303D, No Longer Serviced, Start Year: 01/01/1953
15 1 EAF6306B GEAR Gear, Crankshaft, Start Year: 01/01/1953
16 1 PL PROCURE LOCALLY Key, Woodruff, 5/32" x 5/8", Start Year: 01/01/1953
17 1 86531507 HUB Hub, Crankshaft Pulley, Replaces C0NN6313A, Start Year: 01/01/1953
18 AR PL PROCURE LOCALLY Washer, Flat, 5/8"
19 1 PL PROCURE LOCALLY Bolt, HH, 5/8"-18 x 1-1/4", Start Year: 01/01/1953
20 1 D7NN6A312A PULLEY Pulley, Crankshaft, Replaces P/N EAF6312C, NAA, NAB, Years: 01/01/1953-12/31/1954
20 1 EAF6312D PULLEY Pulley, Crankshaft, L/Power Steering, Except NAA, NAB, Start Year: 01/01/1955
4 PL PROCURE LOCALLY Bolt, HH, W/Power Steering, 7/16"-14 x 3/4", Start Year: 01/01/1955
AR PL PROCURE LOCALLY Washer, Lock, 7/16"
4 PL PROCURE LOCALLY Bolt, HH, L/Power Steering, 7/16"-14 x 5/8", Start Year: 01/01/1953
20 1 C0NN6351A PULLEY Pulley, Crankshaft, W/Power Steering, Except Heavy Duty Industrial, Start Year: 01/01/1955
20 1 C0NN6351B PULLEY Pulley, Crankshaft, Heavy Duty Industrial, No Longer Serviced, Start Year: 01/01/1958
21 1 EAF907A GEAR Gear, Camshaft Hydraulic Pump Drive, 1/4", Years: 01/01/1953-12/31/1955
21 1 EAF907B GEAR Gear, Camshaft Hydraulic Pump Drive, 5/16", Start Year: 01/01/1953
22 AR PL PROCURE LOCALLY Washer, Lock, 1/4"
23 4 PL PROCURE LOCALLY Bolt, HH, 5/16"-18 x 3/4", Years: 01/01/1953-12/31/1955
24 1 C0NN6251A CAMSHAFT Camshaft, Start Year: 01/01/1953
25 1 EAF6256M GEAR Gear Assy., Camshaft, 1.0" I.D., Standard, Start Year: 01/01/1953
25 1 EAF6256N GEAR Gear Assy., Camshaft, .006 O/S, Start Year: 01/01/1953
25 1 EAF6256R GEAR Gear Assy., Camshaft, .010 O/S, No Longer Serviced, Start Year: 01/01/1953
26 1 25121 SNAP RING Ring, Snap, #100, Ext, Gear to Camshaft, Start Year: 01/01/1953
27 1 EAA6278B WASHER Washer, Camshaft Sprocket, No Longer Serviced, Start Year: 01/01/1953
28 AR PL PROCURE LOCALLY Washer, Lock, 7/16"
29 1 PL PROCURE LOCALLY Bolt, Hex, 7/16"-14 x 1.62, Start Year: 01/01/1953
30 4 C0NN6108F Piston, Pin & Retainer Set, .001 O/S, 134" Gas/LPG Sleeve Less, No Longer Serviced, Start Year: 01/01/1955
30 4 EAE6108F PISTON Piston, Pin & Retainer Set, Standard, 134" Gas/LPG, Start Year: 01/01/1953
30 4 EAE6108H PISTON Piston, Pin & Retainer Set, .020 O/S, 134" Gas & LPG, Start Year: 01/01/1953
30 4 EAE6108J PISTON ASSY Piston, Pin & Retainer Set, .030 O/S, 134" Gas & LPG, Start Year: 01/01/1953
30 4 EAE6108K PISTON ASSY Piston, Pin & Retainer Set, .040 O/S, 134" Gas & LPG, Start Year: 01/01/1953
30 4 EBD6108F Piston, Pin & Retainer Set, Standard, 134" Kero, No Longer Serviced, Years: 01/01/1953-12/31/1957
30 4 C0NN6108G Piston, Pin & Retainer Set, .001 O/S, 172" Gas/LPG Sleeve Less, No Longer Serviced, Start Year: 01/01/1955
30 4 EAF6108F PISTON ASSY Piston, Pin & Retainer Set, Standard, 172" Gas & LPG, Start Year: 01/01/1955
30 4 EAF6108G PISTON ASSY Piston, Pin & Retainer, .020 O/S, 172" Gas & LPG, Start Year: 01/01/1955
30 4 EAF6108H PISTON ASSY Piston, Pin & Retainer Set, .030 O/S, 172" Gas & LPG, Start Year: 01/01/1955
30 4 EAF6108J PISTON ASSY Piston, Pin & Retainer Set, .040 O/S, 172" Gas & LPG, Start Year: 01/01/1955
30 4 EAF6108K Piston, Pin & Retainer Set, Standard, 172" Kero, No Longer Serviced, Years: 01/01/1955-12/31/1957
31 4 EAE6135B PIN Pin, Piston, 134", Start Year: 01/01/1953
31 4 EAD6135B PIN Pin, Piston, 172", Start Year: 01/01/1953
32 8 EAA6140A RETAINER Retainer, Piston Pin, Start Year: 01/01/1953
33 1 86551124 PISTON RINGS KIT Kit, Piston Ring, Standard, 134", Replaces P/N CPN6149B, Start Year: 01/01/1953
33 1 86551130 PISTON RINGS KIT Kit, Piston Ring, .020 O/S, 134", Start Year: 01/01/1953
33 1 EAPN6149D PISTON RINGS KIT Kit, Piston Ring, .030 O/S, 134", Start Year: 01/01/1953
33 1 EBPN6149G PISTON RINGS KIT Kit, Piston Ring, .040 O/S, 134", Replaces CPN6149F, No Longer Serviced, Start Year: 01/01/1953
33 1 DJPN6149AA PISTON RINGS KIT Kit, Piston Ring, .020 O/S, Chrome 134", Replaces P/N CPN6149H, No Longer Serviced, Start Year: 01/01/1953
33 1 DJPN6149AB PISTON RINGS KIT Kit, Piston Ring, .040 O/S, Chrome 134", Replaces P/N CPN6149K, No Longer Serviced, Start Year: 01/01/1953
33 1 86539354 KIT Kit, Piston Ring, Standard, Chrome, 134", Replaces EAE6149A, Start Year: 01/01/1953
33 1 EAE6149B KIT Kit, Piston Ring, .030 O/S, Chrome 134", No Longer Serviced, Start Year: 01/01/1953
33 1 86539359 KIT Kit, Piston Ring, Standard, Chrome 172", Replaces EAF6149A, Start Year: 01/01/1955
33 1 86555848 PISTON RINGS KIT Kit, Piston Ring, .030 O/S, Chrome, 172", Start Year: 01/01/1955
33 1 86551113 PISTON RINGS KIT Kit, Piston Ring, Standard, 172", Start Year: 01/01/1955
33 1 86551114 PISTON RINGS KIT Kit, Piston Ring, .020 O/S, 172", Start Year: 01/01/1955
33 1 86551119 PISTON RINGS KIT Kit, Piston Ring, .030 O/S, 172", 1 kit needed per tractor., Start Year: 01/01/1955
33 1 86551123 PISTON RINGS KIT Kit, Piston Ring, .040 O/S, 172", Start Year: 01/01/1955
33 1 86555849 PISTON RINGS KIT Kit, Piston Ring, .020 O/S, Chrome, 172", Start Year: 01/01/1955
33 1 FPN6149J KIT Kit, Piston Ring, .040 O/S, Chrome, 172", Start Year: 01/01/1955
34 1 C3NN6574A BRACKET Bracket, Valve Rocker Arm Oil Inlet Tube, Start Year: 01/01/1953
35 2 EAA6574A BRACKET Bracket, Valve Rocker Arm Oil Inlet & Outer Tube, Start Year: 01/01/1953
36 1 86531523 TUBE Tube, Valve Rocker Arm Shaft Oil Inlet, Replaces EAF6580A, Start Year: 01/01/1953
37 1 EAA6594A SEAL PROTECTION Seal, Valve Rocker Arm Oil Inlet Tube, Start Year: 01/01/1953
38 2 EAA6531A SUPPORT Support, Front & Rear Valve Rocker Arm Shaft, Start Year: 01/01/1953
39 1 EAF6563B SHAFT Shaft, Valve Rocker Arm, Start Year: 01/01/1953
39A 2 PL PROCURE LOCALLY Pin, Cotter, 1/8" x 1.00, Start Year: 01/01/1953
40 2 EAA6532A SUPPORT Support, Intermediate Valve Rocker Arm, Start Year: 01/01/1953
41 AR PL PROCURE LOCALLY Washer, Lock, 7/16"
42 4 PL PROCURE LOCALLY Bolt, HH, 7/16"-15 x 3-1/4", Start Year: 01/01/1953
43 3 ECG6587A SPRING Spring, Valve Rocker Arm Locating, Start Year: 01/01/1953
44 1 EAF6588E HYD. TUBE Tube, Valve Rocker Arm Shaft Oil Outlet, Start Year: 01/01/1953
45 8 F3JL6500AA TAPPET Tappet, Valve, Start Year: 01/01/1953
46 8 C0AE6565C ROD Rod, Valve Post, If replacing a 1/4" OD push rod, must order push rod p/n C0AE6565C, adjusting screw p/n 87801302 & tappet valve p/n F3JL6500AA. If replacing a 5/16" OD push rod, order new push rod p/n C0AE
47 8 EBP6529A ARM Arm Assy., Valve Rocker, Start Year: 01/01/1953
48 8 87801302 SCREW Screw, Valve Rocker Arm Adjusting, Replaces P/N B6A6549C, C2DE6549A, Start Year: 01/01/1953
49 4 EAA6590A WASHER Washer, Valve Rocker Arm Shaft, Start Year: 01/01/1953
50 2 EAA6598A WASHER Washer, Valve Rocker Arm Shaft Spring, No Longer Serviced, Start Year: 01/01/1953
51 2 EAA6572A PLUG Plug, Valve Rocker Arm Shaft, Start Year: 01/01/1953
52 4 EAF6505D CONTROL VALVE Valve, Exhaust, Start Year: 01/01/1953
52 4 EBU6507A STD ENGINE INLET VALVE Valve, Intake, Start Year: 01/01/1953
53 8 EAA6513A SPRING Spring, Valve, Start Year: 01/01/1953
54 4 EAU6514A RETAINER Retainer, Exhaust Valve Spring, Start Year: 01/01/1953
54 4 EBP6514A RETAINER Retainer, Intake Valve Spring, Start Year: 01/01/1953
8 501452 SEAL Seal Assy., Valve Stem, Years: 01/01/1953-12/31/1964
4 C3AE6571B SEAL PROTECTION Seal, Valve Stem, Replaces P/N C1AE6571H, Years: 01/01/1953-12/31/1964
4 D4AE6517AA SLEEVE Sleeve, Valve Stem, Replaces P/N EBP6517A, Years: 01/01/1953-12/31/1964
55 8 EAM6518A BOW Lock, Valve Spring Seat, Start Year: 01/01/1953
55 8 7HA6518 KEY Key, Valve Spring Retainer, Used W/Intake Valves Only, Start Year: 01/01/1953
56 4 8EQ6550A CAP COVER Cap, Valve Stem, Used W/Exhaust Valves Only, Start Year: 01/01/1961
57 1 290421 HUB Hub Assy., Hydraulic Pump Drive Industrial, Start Year: 01/01/1961
1 PL PROCURE LOCALLY Bolt, HH, Industrial, 7/16"-14 x 1.38, Start Year: 01/01/1961
58 4 194342 BUSHING Bushing & Block Assy., Pump Drive Hub Industrial, Start Year: 01/01/1961
59 4 290422 BLOCK Block, Pump Drive Hub Bushing Industrial, Start Year: 01/01/1961
60 6 59A6345A SPARE PART Bolt, Hex, 1/2"-13 x 2.72, No Longer Serviced, Start Year: 01/01/1955
2 1GA6026A Plug, Oil Line, No Longer Serviced, Start Year: 01/01/1953
4 406057B INSERT Insert, Valve Seat Exhaust, Start Year: 01/01/1953
1 8N6087 SPARE PART Cover, Timing Pin, No Longer Serviced, Years: 01/01/1953-12/31/1954
1 EAF6087A SPARE PART Cover, Timing Pin, No Longer Serviced, Start Year: 01/01/1955
