| Ford Tractors Discussion Forum |
Topic: antifreeze change in New Holland TN70
[Return to Forum]
| Author |
[Modern View]
| Fieldman12
07-17-2012 18:43:31
66.87.2.248
I have a 2002 New Holland tractor I want to change antifreeze in. I have Deere,MF, and New Holland equipment. To make it simple I wanted to put in John Deere Cool Guard II antifreeze. I assume this is okay in the New Holland? Anyone else use this in there non Deere equipment?? |
[Reply] [No Email] | |
| sotxbill
07-18-2012 19:44:12
76.183.6.37
Re: antifreeze change in New Holland TN70 in reply to El Toro, 07-17-2012 18:43:31
| you can buy the sca/dca additive from either deere or new holland for almost nothing and add it to any antifreeze, go with the additive and any modern good antifreeze, or go get the pre mix diesel antifreeze and usually pay a bunch more, but go with the proper additive either way to keep the cavitation under control. The more modern diesels were more prone as the engine designs became more efficient... hensce the 10 series and newer were more susceptable. |
| RickB
07-18-2012 14:12:42
69.195.50.147
Re: antifreeze change in New Holland TN70 in reply to Fieldman12, 07-17-2012 18:43:31
| These guys that recommend basic green coolant without DCA/SCA additives aren't qualified to answer the question. Follow Jerry's advise. |
| Blindhawg
07-18-2012 16:33:14
184.46.53.157
Re: antifreeze change in New Holland TN70 in reply to RickB, 07-18-2012 14:12:42
| Any idea what do those additives do for a diesel? |
| Keith Williams
07-18-2012 17:12:49
24.142.137.38
Re: antifreeze change in New Holland TN70 in reply to Blindhawg, 07-18-2012 16:33:14
| Blindhawg, If I understand correctly, they keep little bubbles from exploding on the outside of the cylinders. If this is not done, the walls of the cylinder will develop pinholes. Ford had problems (as did other companies) when the higher horsepower diesels came out in the 70's and 80's. Most larger tractors now have a coolant filter on them that supplies the needed stuff. I believe that the PH and chemicals in the water used also was a factor. Thus certain areas of the country had more problems than others. Fordfarmer knows of this problem. A bottle of FW-15 can be found on the shelves of CNH dealers. I paid 7.03 for it a month ago. HTH Keith |
| Blindhawg
07-18-2012 17:41:59
184.46.53.157
Re: antifreeze change in New Holland TN70 in reply to Keith Williams, 07-18-2012 17:12:49
| Thanks, ya'll have to pardon my ignorance, I'm a lo tech gasser type, but I learned something today! Thanks |
| Blindhawg
07-18-2012 16:50:35
184.46.53.157
| Ok, I"m out of my league! Borrowed this from another forum, Rick, I saw you in there I think. "The terminology of SCA is Supplemental Coolant Additive. Since one company, Fleetguard, makes these coolant additives under the trade name of DCA4 or DCA2, the generic term has become DCA. What these chemicals do in your engine cooling system is to provide protection against cylinder wall cavitation pitting failures. When a diesel engine runs it produces cylinder wall vibrations from combustion and piston slap. These vibrations produce minute movement of the cylinder wall that cause vacuum bubbles to form in the coolant. These bubbles implode (like explode but inward, not outward) against the cylinder wall surface with forces measured at 20,000 PSI. Sufficient force to break out tiny pieces of the cast iron eventually leading to coolant getting into the oil through a perforation. Engine rebuild is the only option then. Use of SCA or DCA creates a tough oxide film on the surface of the cylinder wall (coolant side). The testing of the dissolved SCA level is an indirect means of determining the level of cavitation resistance your coolant has. Even with these additives, the phenomenon of cavitation is taking place. The difference is the hard oxide coating that takes the "blast" of implosion. If you test the coolant and find the SCA level decreasing, you have a strong indication that the cavitation phenomenon is active in your engine. If your Cummins is a B5.9L or QSB (24 valve with Electronic Control Module, ECM) you have no reason for concern regarding cavitation damage. As an employee of Cummins, I work with Mid Range Service (B, C, & L). Only the B engines are immune. C and ISL engines do have cavitation and must have coolants that contain SCA and also require periodic replacement of the coolant filter or use of a liquid SCA additive." |
| Jerry/MT
07-18-2012 10:04:50
206.183.116.145
| If you use automotive antifreeze, you"ll need to add DCA (Diesel Coolant Additive)to the antifreeze for your tractor. If you buy a diesel rated antifreeze, it"s all ready in there. Your call on the brand. |
| Blindhawg
07-17-2012 18:54:42
184.46.53.157
| Simple? How about a good name brand like Prestone? Your tractors won't know the difference. |
| Fieldman12
07-17-2012 19:03:04
66.87.2.248
Re: antifreeze change in New Holland TN70 in reply to Blindhawg, 07-17-2012 18:54:42
| Simple means I want to keep them all the same |
| Rick Sundblad
07-18-2012 05:18:54
108.197.188.223
Re: antifreeze change in New Holland TN70 in reply to Fieldman12, 07-17-2012 19:03:04
| Like the man said Any Name brand like Prestone will work great,the key is like your oil system your cooling system needs to be flushed on a regular basis.Cooling systems under normal use, one time a year is a good rule of thumb.Tractors are usually under heavey duty use, unless they are like mine (1964 ford 4000) a(Shop/Parade Queen).The key is to Check it on a regular basis if it starts to get dirty in color its time to flush and refill.This will keep your cooling system working at "peak" preformance.Also Check your belts for proper tension,system leaks and your waterpump.My wife works for Griffin thermo products so mine has a custom rad.(nascar style) but it still only goes about 15-18 mph down the road only the Rad. tries to go 200 mph LOL!!!!!! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
