Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: new brake drum
[Return to Forum]
Bill Radford
07-10-2012 11:46:14
24.211.160.181
I recently obtained a sparex replacement brake drum for my 641. When I put the wheel back on, the drum's center section is thicker than stock and the wheel does not fit exactly like it did with the original. the entire thread of each lug nut is not engaged with the studs as it was with the original. Is this the wrong drum or is this not something I need to worry about? Brake works perfectly and well over half the threads are engaged.
[Reply]   [No Email]
Billy NY
07-11-2012 07:13:34
67.248.100.3
Re: new brake drum in reply to Bill Radford, 07-10-2012 11:46:14
I installed those Turkish drums on my 850 in '04, they work fine under normal use, also did a complete brake job. At first glance they look thicker, not realizing the original one were steel, I thought it was decent product, and for the most part for what you pay for they are.
I did however really put them to the test, got stuck at the edge of an old field and marsh, one side lower than the other, but not dug in up to the axle or anything. I believe during the process of getting out, I had a bunch of short 2" diameter alder cut nearby, lined the hole and it got the tractor out, was going to rain heavily, not a good place to leave it so I really used those brakes hard, and I think under what I would call light abuse, one drum cracked in half. That was an extreme situation, cant really think of a time I ever used my brakes like that doing regular work, steel is better, my originals are in good shape but on the shelf.
  [Reply]  [No Email]
Texasmark1
07-10-2012 23:51:25
67.142.164.21
I just bought a drum for a 3000 from my local auto parts, farm equipment jobber on the side, guy. It came from Turkey and was in excellent condition; it was even painted. I couldn't tell if steel or cast iron. Was the same thickness as the old one where the bolt holes are. Seems all those tractors of that size used pretty much the same shoes and drums. Actually I put a set of shoes for the 100 series tractors on my '65 3000 under this new drum.
I didn't know old Ford drums were steel till I read it on here. Sure made a difference knowing that when it came time for me to pull it.
Mark
  [Reply]  [No Email]
Doug (OH)
07-10-2012 17:31:57
76.241.107.61
Wonder if it's possible to get slightly longer studs? Doug
  [Reply]  [No Email]
NoNewParts
07-10-2012 16:52:33
67.240.145.25
There are two drums listed, off a 641 on ebay now
cheap
search ebay for
"Ford Tractor Brake Drum 600 700 800 900 2000 4000"
and you'll find em
  [Reply]  [No Email]
soundguy
07-10-2012 14:35:41
184.245.26.45
in general, you want a minimum thread engagement of at least the diameter of the stud / bolt.
for example.. say it was a 1/2" stud.. then you'd want 1/2" of threads.. etc.
if ou had an old time machine shop they could weld and align bore the steel drum then true it.. they might even bolt it to a fixture to weld it.
I've seen this setup using an automated mig, and i've seen it done by hand with stick.
long thankless process that makes buying a good used steel drum a nice prospect.. :)
  [Reply]  [No Email]
Dean
07-10-2012 12:13:40
152.216.3.5
The OEM brake drums are steel. The aftermarket brake drums are cast iron, thicker and prone to cracking.
I suggest that you find a good used OEM brake drum.
Dean
  [Reply]  [No Email]
Bill Radford
07-10-2012 12:37:48
24.211.160.181
Re: new brake drum in reply to Dean, 07-10-2012 12:13:40
Dean:
Old drum is severely grooved,shoes are new. If I could have old drum cleaned up on lathe would it possibly work ok? Old shoes were completely shot, no lining left. Was it the condition of the shoes or drum that was mostly responsible for lack of braking on that side? Left side was like new, right was worn out.
  [Reply]  [No Email]
Dean
07-10-2012 12:48:25
152.216.3.5
Re: new brake drum in reply to Bill Radford, 07-10-2012 12:37:48
Few shops can/will turn OEM Ford steel brake drums.
Good, used OEM drums are readily available and modestly priced.
From the available information, I would recommend replacing your worn drum with a good used OEM drum.
Dean
  [Reply]  [No Email]
Bill Radford
07-11-2012 05:50:02
199.90.157.10
Re: new brake drum in reply to Dean, 07-10-2012 12:48:25
The guy at Worthington ag parts will hook me up with a steel drum.This seemas to be the way to go.
Thanks
  [Reply]  [No Email]
Bill Radford
07-10-2012 11:47:06
24.211.160.181
sorry! double post
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
