Disassembly of Ford 641 water pump
Bob Kellogg
New User
I just replaced the water pump on my tractor and would like to salvage the pulley from the old one. I removed an external e-clip from the shaft inside the pulley housing, supported the pulley housing and tried to drive the shaft out with a steel rod and several dead blows with a 9 lb hammer. It would not budge. Does this require an hydraulic press?
