TractorLinks.com
Order Ford NAA Parts Online
Checking valve clearance on a NAA.
Ozlander
07-06-2012 13:43:15
How often do you need to check the valve clearance on a NAA?
soundguy
07-06-2012 15:22:16
 Re: Checking valve clearance on a NAA. in reply to Ozlander, 07-06-2012 13:43:15
1, every 40-50 ys at least :)
2, Any time you have the head off, or valve cover off.. or do any valve trian work.
3, If you think there is a problem.. like valve tick.. or if you think you have clearances too tight and notice a compression loss or are burning exhaust valves.
soundguy
Ozlander
07-07-2012 10:01:59
 Re: Checking valve clearance on a NAA. in reply to soundguy, 07-06-2012 15:22:16
Sounds like I've about 30 years to go. Thanks,
soundguy
07-07-2012 15:13:07
 Re: Checking valve clearance on a NAA. in reply to Ozlander, 07-07-2012 10:01:59
yep.. if you don't notice a problem.. no real need to just crack her open to check... if you got her open for some reason.. check her.. etc..
Bill Radford
07-06-2012 16:38:25
40-50 years is about right. I had my 641 apart recently and checked the valves. All were spot-on except for #1 and the intake was a couple thousandths loose.
soundguy
07-06-2012 17:22:55
 Re: Checking valve clearance on a NAA. in reply to Bill Radford, 07-06-2012 16:38:25
when I worked on my 4000 a while back. all the exhaust were spot on.. couldn't check the intake as all the push rods were bent to heck.. which was why I was checking them.. :)
