rackerfracker
New User
I"m sort of embaressed to write this. I need info about fluids. I know coolant and engine oil, but i need someone to inform me of all the other fluids and exactly where are the "check plugs", the "drain plugs", and the "fill openings". I need to chage all the fluids because I have way too many years and hours on the present fluids.(2) I also need to know the type and weight of the fluids, is it hydralic fluid, gear oil, or just plain oil?. Are there different oil and resivoirs for the tranny, the rear end, the lift, the PTO? It would be ok if you just directed me to a place with all this info. I cant afford a shop manual, and the old man who used to work on it passed away. He knew more about those tractors. He worked on them for 50 years. He told me all this stuff but i did not write it down and i am old too and my memory is just not good enough. Thank you so much. Shelby from south Georgia
