Have a Ford 3600 diesel tractor that at low RPM"s
runs fine; but in midrange throttle skips like it
is a glow plug engine warming up. Tractor at full
throttle runs good. Has 2 leaks on rubber lines, 1 from tank to injector the other is from injector to injector. Tractor is hard to start
when cold or after running. I have broken metal
inector lines loose to make sure they are working. They all change engine sound when broken loose. What could be problem? THANKS!!!
