851 hyd tube leaks
cdv
started my 851 and oil runnig out all over ,,so pulled motor out and the hydraulic tube in the bell houseing rust out bad to bad to weld is there away to fix or replace them thanks cdv
(quoted from post at 01:50:58 05/11/12) started my 851 and oil runnig out all over ,,so pulled motor out and the hydraulic tube in the bell houseing rust out bad to bad to weld is there away to fix or replace them thanks cdv
Look back 5 are 6 pages for a post were i am replacing a set... I removed the pressure tube by run'n a tap in it and using threaded rod to pull it... I ended up rebuilding the trans and used threaded rod and adapters to remove the suction tube while I had the trans on a engine stand for a rebuild... The issue is not how to remove them its were to get the tubes,,, I got lucky and got a extra tube John Smith made for one of his projects...
[/img]
(quoted from post at 07:12:11 05/11/12) What's that tool on top of your tranny?I thought it was a bottle of beer at first!
GT65
Its a combination clutch alignment adjusting tool I made.. No one could tell me are show me what a original looked like are any measurements it must B a real secret so I made my own... This tractor had a good working clutch so I set the tool up with it at least I will be in the ball park,,, Theirs another piece to it but its just a sleeve to set the height.... Make'n the tools is the fun part... here's another one..
I need to make a bracket so it will fit the right side for tractors like this that does not have a inspection hole on the right side,, it would be nice to be able to reach in their and align the drive shaft when sliding it together...
Hey Hobo, Any chance you got any measurements off that tube you got from John Smith. TOH was thinking of make the tubes if he could get good measurements. See post on the other N-board.
(quoted from post at 19:09:50 05/11/12) Hey Hobo, Any chance you got any measurements off that tube you got from John Smith. TOH was thinking of make the tubes if he could get good measurements. See post on the other N-board.
I don't play well over their so never go their anymore... TOH knows how to get up with me,,, he probably has it figgered out already,,, it would B great if he offered them its not as EZ as it looks to make,, theirs a site that offers them but they are just plain straight tubes that need to be machined to fit...
