part #2 maybee???
1 1 NAA9805C Lever, Throttle Control, 134", All Purpose, Except LPG, No Longer Serviced, Start Year: 01/01/1953
1 1 NCA9805A Lever, Throttle Control, 134", LPG & Row Crop, No Longer Serviced, Start Year: 01/01/1955
1 1 311498 SPARE PART Lever, Throttle Control Diesel, No Longer Serviced, Start Year: 01/01/1958
1 1 NLS No Longer Serviced Lever, Throttle Control, Offset Gas {313394}, Start Year: 01/01/1959
1 1 NLS No Longer Serviced Lever, Throttle Control, Offset Diesel {313400}, Start Year: 01/01/1959
2 1 86536248 ARM Arm Assy., Throttle Control Lever, Except Diesel, Start Year: 01/01/1953
2 1 311500 SPARE PART Arm Assy., Throttle Control Lever, Diesel, No Longer Serviced, Start Year: 01/01/1958
3 AR 352321S36 WASHER Washer, Flat, 5/16"
4 AR PL PROCURE LOCALLY Nut, Hex, 5/16"-24
5 1 PL PROCURE LOCALLY Bolt, Square Hd., 5/16"-24 x 1-1/4", Start Year: 01/01/1953
6 1 NAA9815F ROD Rod Assy., Throttle Control Lever to Bellcrank, Except Diesel, Includes Ref. 7, Start Year: 01/01/1953
6 1 311955 ROD Rod Assy., Throttle Control Lever to Bellcrank, Diesel, Includes Ref. 7, Start Year: 01/01/1958
7 2 C0NN9A790A CLIP Clip, Throttle Control Lever to Bellcrank Rod, No Longer Serviced, Start Year: 01/01/1953
8 1 NAA9824D BRACKET Bracket, Throttle Control Lever, Except Diesel, No Longer Serviced
8 1 311499 SPARE PART Bracket, Throttle Control Lever, Diesel, No Longer Serviced, Start Year: 01/01/1958
9 AR PL PROCURE LOCALLY Washer, Lock, 5/16"
10 2 PL PROCURE LOCALLY Bolt, HH, 5/16"-18 x 5/8", Start Year: 01/01/1953
11 1 NAA9806B SPRING Spring, Throttle Control Lever, No Longer Serviced, Start Year: 01/01/1953
12 2 PL PROCURE LOCALLY Washer, Flat, 3/8", Start Year: 01/01/1953
13 1 PL PROCURE LOCALLY Pin, Cotter, 3/32" x 5/8", No Longer Serviced, Start Year: 01/01/1953
14 1 NAA99778B WASHER Washer, Bellcrank Friction Disc Spring, Except Diesel, Start Year: 01/01/1953
14 1 780344 WASHER Washer, Bellcrank Friction Disc Spring, Diesel, Start Year: 01/01/1958
15 AR PL PROCURE LOCALLY Washer, Flat, 7/16"
16 1 PL PROCURE LOCALLY Nut, Slotted Hex, 7/16"-20, Except Diesel, Start Year: 01/01/1953
17 AR PL PROCURE LOCALLY Pin, Cotter, 3/32" x 1"
18 1 PL PROCURE LOCALLY Nut, Slotted Hex, 5/16"-24, Diesel, Start Year: 01/01/1958
19 AR PL PROCURE LOCALLY Pin, Cotter, 1/16" x 1"
20 1 NAA9827B SPRING Spring, Throttle Control, Governor Compensating, All Purpose, Years: 01/01/1953-12/31/1954
20 1 NCA9827A SPRING Spring, Throttle Control, Governor Compensating, Except Diesel, Start Year: 01/01/1955
21 1 NAA99618C Bellcrank Assy., Throttle Control, No Longer Serviced, Years: 01/01/1953-12/31/1954
21 1 NCA99618A CRANK Bellcrank Assy., Throttle Control, Except Diesel, No Longer Serviced, Start Year: 01/01/1955
21 1 311922 BELLCRANK Bellcrank Assy., Throttle Control, Diesel, No Longer Serviced, Start Year: 01/01/1958
22 1 E6NN9R536AA FRICTION WASHER Disc, Throttle Control Bellcrank Friction, Except Diesel, Start Year: 01/01/1953
22 1 311503 DISC Disc, Throttle Control Bellcrank Friction, Diesel, No Longer Serviced, Start Year: 01/01/1958
23 1 D9NN9825AB CLIP Clip, Throttle Control Governor Compensator Rod Assy., Except Diesel, Start Year: 01/01/1953
23 1 311956 SPARE PART Clip, Throttle Control Governor Compensator Rod Assy., Diesel, Replaced by (2) 44720S36 Washer, 1/4" Flat, and (1) 72003S8 Cotter Pin 1/16 x 1/2, Start Year: 01/01/1958
24 1 NAA99735B STUD Stud, Throttle Control Bellcrank, Except Diesel, No Longer Serviced, Start Year: 01/01/1953
25 1 9828014 KNOB Knob, Choke, Except Diesel, Start Year: 01/01/1953
26 1 NAA99595B BRACKET Bracket, Choke Control Rod, Except Diesel, No Longer Serviced, Start Year: 01/01/1953
27 1 PL PROCURE LOCALLY Bolt, HH, 7/16"-14 x 1.12, Except Diesel, Start Year: 01/01/1953
28 1 NAA9705B ROD Rod Assy., Choke Control, Except Diesel, Start Year: 01/01/1953
29 1 NCA99609A SPARE PART Support, Carburetor Choke Control Rod, No Longer Serviced, Start Year: 01/01/1953
30 1 NAA99817C SPARE PART Rod, Throttle Control Governor Compensator, 134", NAA, No Longer Serviced, Years: 01/01/1953-12/31/1954
30 1 NCA99817A ROD Rod, Throttle Control Governor Compensator, Except Diesel, Start Year: 01/01/1955
30 1 311925 ROD Rod, Throttle Control, Diesel, No Longer Serviced, Start Year: 01/01/1958
31 1 B8NN12A453A STOP Stop Assy., Governor Compensator, Adjusting Rod, Except Diesel, Start Year: 01/01/1953
32 1 NAA99841A CLAMP Clamp, Governor Compensator Rod Adjusting, Except Diesel, No Longer Serviced, Start Year: 01/01/1953
33 1 NLS No Longer Serviced Spacer, .44 O.D. x .252/.254 I.D. x .08 Thick, Except Diesel {352893S}, Start Year: 01/01/1953
34 AR PL PROCURE LOCALLY Washer, Lock, 1/4"
35 AR PL PROCURE LOCALLY Nut, Hex, 1/4"-20
36 1 PL PROCURE LOCALLY Bolt, 1/4"-20 x 1-1/8", Except Diesel, Start Year: 01/01/1953
37 1 NAA99810B TRACK ROD END ASSY End Assy., Governor Compensator Rod, W/Novi Governor, Except Diesel, Start Year: 01/01/1953
37 1 NCA99810A TRACK ROD END ASSY End Assy., Governor Compensator Rod, W/Pierce Governor, Except Diesel, Start Year: 01/01/1958
37 1 311924 HYD CONNECTOR Connector Assy., Throttle Control Rod, Diesel, Start Year: 01/01/1958
38 1 PL PROCURE LOCALLY Nut, Jam, Hex, 1/4"-28, Start Year: 01/01/1953
39 1 86552618 ROD Rod Assy., Governor to Carburetor, Except Diesel, Start Year: 01/01/1953
40 AR PL PROCURE LOCALLY Washer, Lock, #12, Internal Tooth
41 AR PL PROCURE LOCALLY Nut, Hex, #12-24
42 1 352338S8 SPARE PART Clevis, #12-24 Adusting, No Longer Serviced, Start Year: 01/01/1953
43 1 PL PROCURE LOCALLY Pin, Clevis, 1/4" x 51/64", Start Year: 01/01/1953
AR 280236 COTTER PIN Pin, Split (Cotter), 1/16" x 1/2"
44 1 B9NN9A791A CLIP Clip, Throttle Control Rod Connector, Diesel, Start Year: 01/01/1958
