The 3 pt lift on my friend's 600 stopped working last year, someone else resolved this by replacing the lift cover O rings, but he had to double the pressure side to get the lift back. Recently the lift stopped working again which is where I signed on. We removed the cover and it looked like the double O rings were not sealing. I found some dimensions for the OEM O ring, located a replacement, but no improvement so we moved on to troubleshooting the pump. We cranked the tractor with the lift cover off. I understand we should have 1500-2000 psi, oil flowed out of the gallery, but did not "shoot" out. What should I see? I pulled the pump off, I believe it is a NCA600F (piston type). The pistons/cylinders are smooth no obvious signs of wear, pistons move freely in their cylinders, springs appear to be uniform strength. Before we drop significant bucks into a pump, is there a way to better diagnose the pump condition? There is also a problem with water getting into the hydraulic system as the oil was milky. I drained and replaced the reservoir, but are there locations where water typically enters the system?
