Got a hurting tractor. Backed our '65 out of barn, idling for a min, and find what looked like dark antifreeze mix running out of the joint at the starter & block. Pulled it back in barn, left a fat trail dripping along under it.
I hope it's one of the frost plugs on back of the block. CNH parts page says '65's plugs were screw-in plug - are those going to be a bear to get out? Chisel & split?
As for the engine-trans split to get at the frost plugs, can I just disconnect the hyd lines at the pump or should I pull it, too? And, since it's a gasser, am I also looking at also pulling the rear tin, steering wheel, etc.? We have a Ford shop manual but it's not clear about all that.
Am thinking about making up a set of jack stands to screw into the two-bolt bosses on each side of trans/bellhousing. Anyone know what size those threads are? I know, this can be done without fancy stands. But this might turn into the equivalent of the "it's only a little bathroom tile job...." - read on...
I hope, hope it's a frost plug. But the antifreeze in the radiator is milky looking, too. Rut roh. Haven't done a compression test yet. No sign of water in the oil, though. I don't think anyone has ever been into the block.
Well, will be the chance to put in a new clutch, bearing, bushings, seals front & rear...and if the engine has more wrong with it than the frost plug, then maybe look at a rebuild (and then those long-term heavy duty jackstands will beat having everything balanced on wood blocks for for awhile). Engine is on low-ish side of compression and has many thou hours on it, so it's tired too.
Thanks for any answers to my questions. Over the years, I think I've bookmarked every link in here regarding 2000/3000 splits (and about anything else that I didn't know - which is a lot), so have all that info already.
