Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5610 Parts Online
Re: 5610 oil pressure
Bern
02-20-2012 06:19:18
Ditto what everyone else said. I would add: Install your new gauge in an unused port under the oil filter. That way you can compare actual oil pressure with what the light does. The only negative to this idea is that it will be on the unfiltered side of the oil pump (naturally higher pressure), however unless your filter is really plugged, the difference won't be all that great.
Having said all of that, there COULD be another tapping on the LH side of the block where a turbo would be fed from on a 7610. If you find another plug exactly in line with the existing sensor, use that one.
Oil pressure issues on those tractors are RARE. I would suspect faulty wiring or a swapped bulb as the others have already said.
RickB
02-20-2012 14:02:21
 Re: 5610 oil pressure in reply to Bern, 02-20-2012 06:19:18
4 cylinder should have a second test port along the cam line to the rear of the oil filter; in line with the sending unit tucked in by the P/S pump. There would be no differential between this port and where the sender is now.
