I looked in the owners manual but didn't see the answer.
I'm looking at an 850 for sale. Date codes and s/n say it's a 1955. The proofmeter is the original style with the gear numbers on the needle.
There are a row of digits showing the hours. The first several digits are black on a white background. The next to last one is white on a black background. The last one is just alternating white and black blocks.
Now for the question: does that last digit (just before the white/black blocks) indicate tenths of an hour? Or is it a full hour? This hourmeter shows 0400 on the white blocks with another 0 on the black block. With the tractor running, the last counter with just alternating white & black blocks is turning.
Is it possible for this tractor to have only 400.0 hours on it? Or am I seeing 4,000 hours on that meter. It does not appear to be a replacement meter. If it is, it was replaced a long time ago as the "white" number blocks are significantly yellowed.
I forgot to look closely at the clutch pedal for wear. I should do that.
