851 ford tractot tool
Anonymous-0
i am looking for 15 spline havey duty clutch linement tool, bought on from napa didn't fit the tractor.
is there a cross over one that fit this 851 tractor
You have the tool. Unbolt and remove the input shaft from the front of the tranny. All it'll cost you is a new gasket. May as well replace the seal too since you're already there.
I have done four, including a double disc,without an alignment tool. Just put the clutch onto the flywheel with bolts just tight enough for very slight pressure. then you can move the disc with a screw driver or large drift or small bar to get it in line. Then tighten it down.
