Where is the bleed screw for hydraulic system
Anonymous-0
Its a ford 800 with single clutch five speed transmission. Just in front of the base of my seat on the hydraulic pump cover is a hex bolt. It seems to be sitting a little higher than the rest of the bolts. Is that the bleed screw? Thank You for your reply.
The plug used to bleed air from the pump is located on the pump cylinder head near the front. It is an allen head, rather than a hex head plug.
Dean
top right
the plug int he 3x5 cover in front of the seat has various uses.. could be a source of SA hyd power if you chain your lift down.. or could be used as a test port for a gauge.. etc.. etc..
soundguy
