Brian Saylor
New User
I have a '55 860. Runs great 99% of the time. When it really counts, it seems to starve for fuel and shut off. If you wait 20 seconds and restart, it runs for 1 minute. If you wait 10 minutes, then it runs for 20 minutes. I cannot determine if the float isn't supplying enough fuel into the bowl or if the line from the tank is not. I take off the line from the sediment to the tank and it flows fine. I can shoot air into the line and it doesn't fix the problem. I bang on the side of the carb bowl and nothing gets fixed. The carb is rebuilt and has all new jets, valves, etc. This only occurs when running at 1800 RPM or greater. If I run at 1200 rpm, it will run all day long. But not fast enough for a mower.
