I recently had to replace my manifold on a 55 860.
The new elbow 1 5/8 does not fit the hole in the manifold like it should. The bolt holes line up but the elbow has a lip that supposed to stick down in the manifold tight to give it strength I guess and smooth exhaust flow. This one has a 3/16 gap all around the lip. YT said there all like that unless you go to a elbow with a 2 inch outlet, it has a bigger base that fits the manifold perfect. I went ahead and put the 1 5/8 elbow on, thats the size of the muffler. Now I have to run a rich setting on my carb main jet to get the tractor to run. The rich setting is killing my plugs and Im getting a unburnt fuel smell from the breather. The idle mixture was not effected. Could this have anything to do with the new elbow? With the old manifold, as bad of shape it was in, the tractor ran perfectly.
Thank you for any help,
Todd
Todd
