TractorLinks.com
Order Ford 4000 Parts Online
Re: 1964 Ford 4000 hyd lift stuck in up position
soundguy
02-05-2011 15:01:39
could be a sticky unloader valve.
if you need to get it down, you can pull the plug on the 3x5 option cover on the lift cover and oil will shoot out and it will drop.
might lift the lift and work the handle up and down a bit and see if the unloader frees up.
soundguy
Bern
02-06-2011 06:57:44
 Re: 1964 Ford 4000 hyd lift stuck in up position in reply to soundguy, 02-05-2011 15:01:39
Might wish to be careful with that option if there's weight on the hitch!
soundguy
02-07-2011 06:25:13
 Re: 1964 Ford 4000 hyd lift stuck in up position in reply to Bern, 02-06-2011 06:57:44
that falls under 'common sense!'
soundguy
henryjo
02-05-2011 15:20:22
Thanks for the assist. I will try your suggestion - it"s nighttime where I am so will try it out tomorrow.
henryjo
02-06-2011 10:14:27
 Re: 1964 Ford 4000 hyd lift stuck in up position in reply to henryjo, 02-05-2011 15:20:22
To Soundguy: Thanks again for what to try on the stuck lift. It worked. I also moved the lever up and down as you stated. It seems to be working smoothly again. I was wondering if there is any type of hyd. oil additive that I could add to help it?
soundguy
02-07-2011 06:26:21
 Re: 1964 Ford 4000 hyd lift stuck in up position in reply to henryjo, 02-06-2011 10:14:27
nope.. it's already 'oil'.. might need to be clean oil though if the sump is dirty or emulsified..
soundguy
soundguy
02-05-2011 15:27:19
awe schucks.. that's what lanterns and flashlights are for!
