I recently bought an 860 with a Vickers vane pump. Got her home & hydraulics wouldn't work. Got lots of great advice here about how to prime the pump but was also cautioned that my problems probably weren't over. Guess what.
Pump will keep a prime for about two days shut down but then I have to re-prime. I understand that the common cause is a worn shaft seal. Am I better off rebuilding the pump, installing another vane unit or converting to a piston pump? If piston pump is the way to go what am I getting into in regards to the hydraulic lines -- currently I have a nice one-piece aluminum casting that I assume conceals the two lines.
Thanks,
Pete P.
Harborcreek, Penna.
Thanks,
Pete P.
Harborcreek, Penna.
