lonestarjeff
Over the last weekend I put the 860 back together far enough to turn it over w/ the starter. All fluids in, wiring harness hooked up, plugs out & a little dash of oil in each cylinder. I turned it over a few times w/ the hand crank before installing the battery & starter. Turning resistance was about what you'd expect w/ the plugs out.
After installing the battery & starter it would just barely turn the engine over...very slow....then nothing but the dreaded "click" of the relay. My 1st thought was the battery(which has been on the shelf about a year); however, I've been pretty good about hooking the float charger to it about once every 6 weeks.
Temporarily ruling out the battery, I went back thru all my connections to make sure I was getting clean metal, plus I checked the starter/bell housing surfaces again. Still the same poor grunt & quit.
Just for grins I checked the battery state of charge again & it was way down....more than it should be for a few hits on the starter. That was enough for me to take it back to TSC for another battery. Their little meter said it was charged, but the CCA was down about 50%. I'm not sure, but I would think even 300 amps should turn over a 4 cyl w/ the plugs out.
I took the new battery & hooked it up to get the same performance. The only thing I can think now is the starter is siezed. I pulled the battery off & tried turning the engine w/ the hand crank again, but it won't budge.
So, it looks like I'll be using that spare starter rebuild kit I purchased for the 8N several years ago. Unless it's a short in one of the field coils or armature.
Anybody know the symptoms of a starter expiring well enough to make a diagnosis? Just for a little background, I started the tractor a few times when I brought it home. It had a 12v battery on it which spun it plenty fast, but I installed the new 6v battery, cables, & harness back then & it would start it, but really had to grunt. I passed that off to some rusty ground connections, but now I thinking the starter was on its way out.
Jeff
Jeff
