working on a 960 hydraulic top cover that will not raise. took it apart and found that the unloader valve was stuck, replaced the oring and cleaned the bore and got it working like new. put the cover on and it worked fine. parked the tractor and went out two days later to no hydraulics again. I have now had it off 3 times, the valve has not siezed up again, but now i have found that when i air check the top cover installed on the tractor with the cross over plate off of the top and put air to the pressure in port on the top, it blows back out of the back pressure valve and into the return port without moving the unloader valve or anything else in the system. my question is, what could cause the pressure to go back to the sump? all of the linkage and valving seems to be working corectly other than the unlaoder valve. i feel i am missing something, but i don't know where. i fear i am going to have to pull the cover agian unless someone has some wisdom to help a Deere guy out on this old Ford. thanks alot.
