Anonymous-0
I am looking at an 860 tractor with a 5 speed transmission live pto that has a bad 4th gear. He said he was driving it and took it out of gear without the clutch and it locked. He was able to take out the fill plug and move the gearing with a screwdriver and it worked in all gears except the 4th gear. If he puts it in 4th it locks up again. He has taken the cover off and the shifter forks are good. Does anyone know have bad this makes it? Does the tractor have to be split and are parts available? I would be willing to try to split it and fix it, but if this is such a nightmare and expensive, I will run before I get into it. Thanks Lyle
