tree grower
New User
I just searched the archives for the past year re: power steering, and believe someone out there can answer my question. My 850 came with a Ford Escort power steering pump (I think). It didn"t work fast enough, so I put on another of the same, with the same results. I just finished fabbing brackets for a mid-70s Chevy pump, and results are the same again. With a pressure gauge hooked up per repair manual instructions, the three pumps all generate only 700 PSI. The manual says I should have 1350 psi. This sounds like a relief valve issue. Where do I find the relief valves in these pumps, and can I buy other valves? Thanks in advance for any help.
