Trying to figure out whether I have a problem with fuel or Coil. Starts great, Idles fine and can operate for about 10 or 15 minutes then starts hesitating and if you let off of the gas it will settle down but if you put it under a load as in using a box blade will start hesitating again. I have checked the fuel bowl and it had a small amount of brown powder and gas smelled rank so I drained the tank and carb then refueled the tank. It seamed to work fine but here we go again with the hesitating until it died. I can let it cool of for half hour crank it up and use it for again 10 or 15 minutes before it starts again
