Ok this started last year when my pto would not stop turning with clutch pedal all the way down. The clutch was adjusted all the way in with no more left so I assumed it was clutch time.
last Saturday I split the tractor and noticed one of the three adjuster bolts had worked its self all the way in and the stop nut was laying in the bell housing. This bolt should have been out about 3/8 of an inch but instead was flush. This resulted in only two of the three clutch actuating arms doing their job.
Now I am undecided on what to do. I cant find any technical data stating the two friction discs should be a certain thickness before replacing or that they have so much life left in them...
I am going to replace the two discs and pilot bearing and throwout bearing since I am there but am thinking on re-using the pressure plate since I have the means to open it up. I just dont have a good method for checking the springs. What would you guys do if you were in my shoes? Also, I am thinking of buying all the parts from this site. Any good reason why I should not?
I also noticed a transmission front seal leaking so I will replace that also as well as the rear main engine seal.
Thanks in advance for your help.
