Topic: Ford 3000 Fuel pump problem
[Return to Forum]
| Author |
[Modern View]
| 7gregory
01-21-2010 11:43:53
75.131.251.199
I have been using my ford 3000 tractor for 10 years now. I haven't used it in 3 months and went to crank and won't crank. It is upper 70s today. I am getting white smoke while trying to crank. I noticed the diesel fuel line closest to the front is not getting diesel. the other two are getting diesel fine. I changed the two fuel filters and they were terrible clogged. I am sure their is pluggage going to that line in the inline simms fuel system. I did the hand pump and cleared the air all the way to the injectors on the two good lines. seems like it should still crank on two cylinders. how do I clean the inside of the simms fuel pump. the little manual hand pump works fine. I tried blowing air at the inlet of the simms pump and that didn't help. I unscrewed a bolt on bottom of simms and rusty water poured out. I don't even know what that was for. any advice on what to do would be greatly appreciated. |
| Greg Christian
02-28-2010 11:32:16
158.35.225.231
Re: Ford 3000 Fuel pump problem in reply to 7gregory, 01-21-2010 11:43:53
| Ok I changed the manual fuel lift pump and fresh oil in fuel pump. still no diesel will come out of the front fuel line. I get fuel out the other lines and tractor will make a lot of white smoke but will not crank. what could prevent it from getting the fuel. |
| sotxbill
01-22-2010 07:57:10
76.227.27.16
| | ref to bolt on bottom of simms pump rusty water was diesel fuel and lube oil.. you drained the lubrication out of the pump.. you will now burn up the pump. fill it back up with oil per the book before going further. |
| 7gregory
01-21-2010 19:35:00
75.131.251.199
| Why would two cylinders get Fidel and no diesel to the front cylinder. |
| 7gregory
01-21-2010 19:32:53
75.131.251.199
| What kind of oil do I use and does it go in where the bolt that has the vent
lime on it on the left side. |
| Shaun Wallace
01-21-2010 17:52:05
71.21.79.43
| Bet oil in pump cambox hasnt been changed in long time. Makes had to start and run. |
| RickB
01-21-2010 13:54:05
74.209.23.185
| "little manual hand pump" is likely bad. A failed diaphragm will let air into the system. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
