Chris62877
New User
Looking for info on a 1976 Ford 515 Industrial tractor.
Weight of tractor
Type of transmission oil and amount.
Type of rear end lube and how much.
Type of power steering oil and how much.
I am needing info on the holley carb, ignition timing, valve adjustment,
Web site dealing with this tractor.
And is this tractor basically the same as a 4000 model? If it is most of my questions will be answered easily. And parts locating will be much easier also as then most parts will interchange.
This is a 3cyl gas
8 spd
3 point
ind 540 pto
loader
power steering
Thank you
Weight of tractor
This is a 3cyl gas
8 spd
3 point
ind 540 pto
loader
power steering
Thank you
