Ok, I purchased a loader from e-bay from another forum member and then had to build brackets to get it mounted and did so with help from a friend who machined the plates.
After some trial and error I found that my tractor already had the selector valve to allow the loader to work, I just needed a hose. I knew the valve was there, but the local New Holland parts people explained how it worked and they were wrong. Go figure. Anyway, for those that want to know, you remove the top port and hook up a hose and then pull the lever forward and the loader works up and down with the standard hyd lever beside the seat. Push the lever aft and only the three point works. Put it in the middle and both units work at the same time. So, I raise the implement I do not want to use and switch the lever and the just raised unit stays hydrauliclly locked in the up position and then you have full control of the other. I will try and post some pics.....
I still have to rework the bucket, but that should not take more than a day or so welding. I purchased a 10' piece of 1" square to make the missing teeth out of and then I am going to weld in the dirt pand and add sides. I will post pics when I get it done.
What do you all think of painting the loader red? I like the looks of the red loaders even on a blue tractor and I can use rustoleum paint and I love that paint and you can buy it by the gallon.
Also thanks to Soundguy and the rest of you that posted pics and information that allowed me to get ideas and make it happen : )
