I recently purchased a One arm for my 3000. I havent picked it up yet but am already starting to get ready to mount it. I have questions about the type of valve required as I do not really understand after looking at them on-line and end up with more questions than answers.....
first of all, I have the port under the seat that allows you to select between 3-point, aux out, or both at the same time. I would like to mount a valve either on the loader or close to it and not under the seat. I will feed the return ibnto the top of the rear axle fitting where you service it by tapping and installing a fitting. I also want to keep the costs as low as possible.
Second, the loader is a trip type so I only need a single valve but have considered converting it to hyd tilt by building my own brackets so I would need a dual valve at some time in the future. Can I buy a dual valve and cap-off the unused side for a later date?
do I need a three port or four port? Open or closed center? does the float option matter and what is it used for?
As far as plumbing goes, does the cylinder return thru the valve also? I see most valves have a inlet and outlet port as well as work ports. Which is which?
Sorry for all of the questions, but I just do not know which way to go. Thanks in advance.
