My 1958 model 851 diesels when turning off ignition. Last time I was on my prperty(240 miles away) I thought I would check to see if the timing was perhaps off. Unfortunately the the Craftsman timing light(haven't used in many years) was not operational any more. I know that it could be a carbon buildup problem. But I want to see if perhaps changing the timing might cure this problem. Without using a timing light which way should I adjust the distributor, lower rpm's or higher rpm's? I do have a Craftsman engine analyzer with DWELL check, perhaps that can also be used? How? Thanks. Joe in NYC.
