Engine was running great when it was shut down. About 2 months later it wouldn't start. Found no fuel getting to filter. Drained fuel tank found strainer plugged. Cleaned strainer and shutoff valve, dumped fuel, replaced with new. Replaced fuel filter, vented filter until full of fuel. Open the vent on the fuel pump, turn engine over until it squirted a stream of fuel. Loosen connections on injector lines at all 3 injectors. Tried the starter several times and for as long as 20 seconds each time. No trace of fuel at any of the injectors? The connections are finger loose.
I've never had this problem or tried venting the injectors but I feel the pump should be putting some fuel out the loosen connections. I would think the pump should pump a little at no pressure even if the pump has became faulty?
What next?
I see a connection on the fuel pump at each injector line. It looks like a cap. I'm not talking about the union on the injector line. What is the purpose of this connection?
What next?
