Of the many problems on our 1985 Ford 7710 tractor, the current one I am working on is the elctrical system. The A/C, Wipers, and Radio will not work. I have replaced the three pronged relay under the dash that divides the voltage and yet I still get the dreaded red alternator warning light in the upper right hand corner. The fuses are good, and I just replaced the entire wiring harness that is on top of the cab. The harness is correct, because the dome light works. Has this happened to anybody else? Does anyone have any thoughts on the matter, or at least where I can pick up a wiring diagram? Way too hot to drive this tractor w/o A/C.
