I started the disassembly on my 860"s gear box.I have it removed from the tractor,arms,steering wheel,and sector gears removed.The upper and lower bearings in the column are shot.
How do I get these bearings out.Do I press the steering shaft threw the column housing.I"m just asumming that both bearings are installed from the top.I understand I should not remove the ball nut.
I think after I get these swapped out I"ll be ok,are the metal bearings still available?The bushings the sector gears ride on looked and felt good,the seals need replaced all the way around.
Thanks for the help guys.
