I have a Ford 860 tractor that has been acting up and I can't figure it out.
When the tractor is cold it will start up and run with out a problem. However after an hour or so of use it will bog down and the motor will start to hunt. I can get it to run smoothly by adjusting the fuel mixture screw on the carb but it will only run smoothly for 10-15 minutes before it all starts again. If I adjust the carb again it will run well for another 10-15 minutes and then the cycle repeats. It seems that in most cases I adjust the carb to a richter mixture to get it to smooth out but not always.
I have re built the carb but no change.
Any ideas?
Thanks for your help.
Any ideas?
