Jim S - NY
New User
Quick Summary - Power steering quit working in the winter of 2007. Once the weather warmed up it started working again after turning the wheel locked-to-locked a few times. Ran all of last summer without an issue. Backed it out of the barn in December, it worked, pulled it forward and power steering quit again. I had a leak at one of the lines. Tighted the nut and turned the wheel back and forth to try to get any air out. If I turn the steering wheel slow, the power steering seems to work as I can turn the steering wheel with 1 finger. If I try to turn the wheel at a normal speed, it does not work. Pulled the reservoir apart and discovered the filter was slightly off its seat so all of the return fluid was not going thru it. Any ideas would be apprecitiated. Thanks.
